275/40- 20 Tires
Discussion in 'Challenger Wheels, Tires and Brakes Forum' started by SRT-Tom, Jan 26, 2018.
    If anyone wants to know, you can install 275/40-20 tires on stock 9" wide wheels on the front and rear of a 2008-2010 Challenger SRT without clearance issues.
    The 9" wheel (rim width) is right in the sweet spot for 275/40 tires. Essentially, the 275/40 is a "plus zero" size up from the stock 245/45 tire. The diameter and sidewall heights remain the same. You are just shifting the tread width size and compensating with a lower aspect ratio.
    Here is a photo of the rear tire clearance.
    Hopslayer, BobFake and IntimidatorRT like this.
  2. BobFake
    BobFake New Member
    Bethany Beach, DE
    I did this on my 2014 SRT Challenger which came with 245/45 in the front and 255/45 in the rear. I went up to 275/40 in the rear and 255/45 in the front with no issues and no affect on the speedometer.
  3. Hopslayer
    Could you put a 295 on the back with a different rim, or would you just have other problems? I assume you put the 275 on the stock rim that came with the car and a 245 on it?
  4. HemiFeverAZ
    San Tan Valley Arizona
    what about having he SRT lowering coil spring package? my long tubes already hate my roads lol
  5. IntimidatorRT
    the 275/40/20 size will be my next set of tires. I know a guy who has them on the front of his RT and has 295/40/20 on he back, but has 10 in rims on the rear.
    The 275/40-20 tire also looks great on the rear. Check out my 2009 SRT.
    IntimidatorRT likes this.
  7. B5blueRT
    Flowmaster axle back exhaust, Saleem Roadrunner hood, air intake, larger 20" tires, tuners... you guys are trying to spend all my secret stash... you're killin' me!!! Heh, Heh!! :favorites13::emotions133::Nonono::):):)
  8. HemiFeverAZ
    Wanna see some 315s under the a$$
  9. IntimidatorRT
    those will require at least a 10" rim.
    HemiFeverAZ likes this.
  10. 70-426_10-SRT
    I love the looks of my 275/40/20 front and 295/40/20 rear on stock 9" SRT rims.
    Really wanted 285/40/20 for the rear, but found these used for cheap and already have over 15k miles on them.
