Engine tick
Discussion in 'Dodge Challenger General Discussions' started by Josh82, Oct 14, 2019.
    I think that the tick is more common with the 5.7s. My 6.1 doesn't have it. I use Mobil 1 0W-40, per factory specs.
    baccaruda likes this.
  2. DodgeCares
    DodgeCares Active Member
    Auburn Hills, MI
    Sorry you're experiencing this! Shoot us a PM if you need help with anything and I'd be glad to look into it for you.
    Steph
    DodgeCares
    We'd be glad to look into this for you as well! Our PMs are open if you'd like to speak further
    Steph
    DodgeCares
  3. STEVEN NIX
    STEVEN NIX Active Member
    long island new york
    i am a tech for JEEP CHRYSLER DODGE RAM. i have a 12 R/T classic. most of the tick noises we hear have been camshafts on MDS equipped engines. i have yet to see it on an EZC motor.( stick w/o mds) we have also heard valve guides. if you have a miss accompanying the tick, more than likely a worn cam lobe. if not, probably a valve guide, requiring a head replacement. maybe you can turn this into a positive opportunity and try a mod you may have been thinking of. BEST OF LUCK, STEVE.
    Josh82 and IntimidatorRT like this.
  4. Josh82
    Josh82 Member
    Ohio
    I just replaced all the plugs it was doing it before I changed them and still does after but it does kinda go away when I give it gas and comes back especially when I shift
  5. HemiFeverAZ
    San Tan Valley Arizona
    That sounds more like exhaust leak have you recorded a video
  6. Josh82
    Josh82 Member
    Ohio
    Thanks and I'm not sure if it's a miss that is causing this but it sounds like a popping noise coming from the back of the car it doesn't always do that though just every once in a while so if it was a miss wouldn't it be more consistent
  7. IntimidatorRT
    Someone needs to post in English.
    s3ood20013 likes this.
  8. SRT-Tom
    أرسلت بواسطة iPhone بإستخدام Tapatalk[/QUOTE]
    Reported as possible Spam.
    IntimidatorRT likes this.
  9. 2017 Redline HC
    o_O:confused:
  10. B5blueRT
    This doesn't sound encouraging. Mine's had a tick since day 1 as a new car. A bad camshaft???? I'm not going to spend $100 for the service agreement deductible on a 4 yr old car with 9,000 miles to have the dealer tell me it's normal. I'll let mine go until it blows up.
