Check out this nicely done 1969 Camaro Resto-Mod. It has the following features: 377 c.i. LS, 4.075-inch bore, 3.622-inch stroke at 10.5:1 compression.* Ported GM LSA heads. Wiseco pistons. Custom camshaft. Brian Tooley Racing platinum spring kit. GM valves and CHE trunnion kit. LSA supercharger with custom intake tube connecting it to a Rotofab airbox. Fabricated primary headers from a Stainless Works 2-inch kit and chambered mufflers. Tremec T56 Magnum with a Monster twin clutch. TCI pro touring independent front suspension system with Ride Tech double shocks. TCI swaybars on both ends (1.25-inch front, .75-inch rear). TCI rack-and-pinion steering upgrade. Forgeline GA3 wheels with Nitto NT01 tires (275/35-18 front, 335/30-18 rear). 14-inch Wilwood brakes (6-piston front and 4-piston rear). *Note- The engine dimensions are very similar to the 6.1Hemi- 370 c.i, 4.06 bore, 3.58 stroke. Revolution in Blue 2: 1969 Camaro Restomod Resurrection | DrivingLine
That seems to be the new trend and gives a lot more reliability but I'll stick with the Day Two mods I did to mine.
