2010 Numbered Challenger R/T 5.7L V8 Hemi Standard transmission w/appearance package
Discussion in 'New Member Check-In' started by Ziva David, Mar 24, 2023.
  1. Ziva David
    Ziva David New Member
    Tampa, FL
    I purchased this car new in 2010.
    She is having issues with the steering column joint. It rubs and squeaks. After some research, I've found that there is not a replacement ball joint for the 2010. I suspect I may have to go Old School and grease the joint. There must be a special grease for this, right?
  2. Ziva David
    Tampa, FL
    Had to go Old School and grease the part because there is no replacement part for 2010 Challenger R/T.
  3. Niles
    Niles Full Access Member
    Huntsville, AL
    Which joint did you grease?
