2016 scat ran hot today
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by nitrovette, Oct 18, 2021.
  1. nitrovette
    nitrovette Member
    Was just driving around in a neighborhood and my car started running hot got pulled over as fast as possible. When I opened the hood my reservoir was filling up . After letting it sit for about a gr the reservoir had dropped back down to normal fill line . Oil was not milkshaked no smoke out tail pipes cranked up fine drive it onto the flatbed . Could this have been a stuck thermostat and after sitting it opened back up letting water out of the reservoir? Since it was full when it ran hot .
  2. Wm TPA SXT
    Wm TPA SXT Full Access Member
    You got a 2016 Challenger?
  3. nitrovette
    nitrovette Member
  4. nitrovette
    nitrovette Member
    Sorry 2016
    Wm TPA SXT likes this.
  5. Hopslayer
    I swapped out my thermostat for a Mishimoto 180 degree one. It failed 3 months later and my engine got up to around 245 degrees. I bought a new 180 from Ripp and it's been perfect. My mechanic said unless I hit about 260 degrees, there's no problem. You hit 260 or higher and you're ruining cylinder heads, etc.
    Cloverdale likes this.
  6. nitrovette
    nitrovette Member
    Well they replaced both fans now they run . But it started doing the same thing filling the reservoir back up again so they replaced the thermostat since it was all crapped up car runs fine now . Hard to believe fans and thermostat went bad all at the same time ?
  7. nitrovette
    nitrovette Member
    Both fans were broken found out today .
