426 HEMI History
Discussion in 'First Generation Challenger Forum' started by SRT-Tom, Oct 10, 2024.
    Sexy Blue likes this.
  2. Sexy Blue
    Sexy Blue AKA Bob
    Hudson Valley, NY
    Beautiful, and ready for the Dyno.
    So spark plugs were installed in the valve cover opening like on modern engines?
    Yes. Here is a photo of a 1971 Street HEMI.
  4. Cloverdale
    One difference being that you'll find an additional one for each cylinder (which many are unaware of at time of car purchase).
  5. Sexy Blue
    Sexy Blue AKA Bob
    Hudson Valley, NY
    Where is the additional spark plug? I only see 8 single wires.
  6. Cloverdale
    Our 8's have 2 plugs per cylinder.
  7. Sexy Blue
    Sexy Blue AKA Bob
    Hudson Valley, NY
    So if I pull the coil pack, I would see 2 plugs? Gotta dig deep in your pocket for 16 spark plugs I guess. And we still have ignition wires that cross over. Quite the design.
  8. SRT-Tom
    He was referring to the modern-day HEMI engines, like the 6.4.
  9. SRT-Tom
    Here is a HEMI coil pack that connects to two spark plugs per cylinder on a 5.7, 6.1, 6.2 or 6.4.
  10. SRT-Tom
    Many question the unconventional reason for two spark plugs per cylinder on modern HEMI engines. The answer lies in the design and shape of the combustion chamber and valves. Take a look at the picture of the heads of a 5.7 Hemi below.
    The valves on the 5.7 Hemi take up so much space, that there’s hardly any room in the center, let alone enough space to fit a spark plug. Keep in mind that the center is the most optimal place for a spark plug.
    Obviously, the only logical way to go around that is by placing a spark plug in a corner, but that creates another problem.
    If Dodge put a single spark plug in a corner, then the engine would have two problems- the mixture wouldn’t fully combust, and the flame would have to travel from one side to the other side. This would be incredibly inefficient. To fix that, Dodge simply decided to put another spark plug on the opposite side. While this is not ideal, it does minimize the potential issues caused by the shape of the combustion chamber and the size of the two valves.
    The benefits of this shortened flame-travel configuration are slightly more power, better fuel economy, and significantly fewer NOx emissions.
