6.1L 6.1L Intake manifold bolts.
Discussion in 'Challenger SRT8 Engine & Performance Modifications' started by BBBAD345, Nov 3, 2020.
  1. BBBAD345
    BBBAD345 Full Access Member
    USA
    When I removed my 6.1L intake, all of the original plastic bushings were broken. The 6.1L intake manifold bolts are not avail any more from Mopar from what I can see, and all of the aftermarket bolds do not have the bushing or a proper shoulder from what I have seen either. This is how I solved the problem.
    Fig 1. I bought 11 of these metric bushings from Ace Hdwr for $0.30 ea.
    Fig 2. Use a 6mm threaded rod or bolt to roll the bushing on in order to make it easier to cut (use a glove). Cut the bushing in half as shown.
    Fig 3. Test fit bushing on bolt.
    Fig 4 & 5. Install the bushing into the manifold.
    001 Bushings to use.jpg 002 Cut bushings.jpg 003 Fit bushing on bolt for proper fit.jpg 004 Install bushing into intake mnfld.jpg 005 Correct installation.jpg
    baccaruda and Fixdaserver like this.
  2. 2017 Redline HC
    Looks to be a good work around.
  3. Fixdaserver
    Fixdaserver New Member
    Jupiter, fl
    This is exactly what I was searching for today. Thanks for posting.
  4. Cloverdale
    Original bolts could well be torque to yield (TTY) due to securing aluminum manifold and may need to be replaced.
  5. Niles
    Niles Full Access Member
    Huntsville, AL
    You may be right, but that is unlikely as the torque is less 108 in-lbs. That is less than 10 ft-lb and not enough to distort the bolt.
    Fixdaserver and Sexy Blue like this.
  6. Cloverdale
    There are a variety of potential issues involving Dodge intake manifold bolts through a variety of current displacements. Torque spec on the video application is also less than 10 ft lbs. I've recently broken a reused bolt of similar capacity just snugging it up (thinking it unlikely while applying such a minimal amount of torque).
    Bing Videos
  7. Niles
    Huntsville, AL
    Galling can occur more frequently in some metals. I think aluminum and stainless steel are more prone to it than carbon steel. That can make it easy to break bolts. No pun intended, but I'm a little rusty in my metallurgical knowledge.
  8. Fixdaserver
    Jupiter, fl
    I ended up using white rubberized screw end caps. They fit perfectly over the intake manifold 6mm course thread bolts and are the proper diameter for the manifold collared bolt holes.
    Sexy Blue likes this.
  9. Cloverdale
    I've read reports of the 5.7 intake manifold bolts working themselves loose and that Dodge discontinued use of the 6.1 aluminum intake design due to a propensity to overheat compromising it's (and it's bolts) integrity (ability to remain sealed and to be resealed). My metallurgic knowledge likely falls well below yours.
  10. HellKitten
    HellKitten Full Access Member
    NH
    This is how the engineers get you to purchase another vehicle after 5 years or so .
