I have a 2015 Challenger 392 srt 6spd manual trans 900 miles on the car trans seems to shift hard 2nd gear is worse
Have you taken it to a dealer to have it looked at? Being a 2015 should still be under warranty and transmission issues are covered in the powertrain warranty.
I was hoping that Dodge had fixed the bloody Tremec's by 2015. There are links all over the internet about how crappy the Tremec's are/were. Definitely take it to Dodge and site Star case # S1021000004 or K38556860. Those were the numbers for the "voluntary" recall for the earlier Challengers. I bought mine used with a 3rd party warranty and ended up paying over 5k to get mine fixed last year. Dodge Star Case # S1021000004 or K38556860 Vehicle Issue Trans is hard to shift into gear. Year 2009 Model LC - CHALLENGER Engine 6.1L SRT HEMI (SMPI) V8, 5.7L HEMI VCT, 5.7L HEMI VCT MDS (EZD) System or Component;Gear Driver Input / Vehicle Operation; Shifting Case Verification; Vehicle affected is the LC Challenger equipped with a manual transmission. It may be difficult to shift in and out of gear. Recommendation ;Repair this condition by removing the transmission, cleaning the transmission input shaft splines and the clutch hub splines, regreasing, and putting all the same parts back together. No parts need to be replaced because clutch disc wear or shaft/hub spline wear are not contributing factors. The clutch should be removed from the flywheel to properly clean the clutch splines, because it is not possible to thoroughly clean the clutch splines otherwise. Do not use harsh spray solvents (brake clean, etc.) on the clutch discs... care must be taken to keep cleaning solvents away from the clutch friction material. Mineral spirits or similar will get the job done. Both of the clutch hub splines and transmission input shaft splines must be carefully cleaned. When applying the grease for reassembly, the entire exposed length of the clutch hub splines (both discs) and the entire length of the input shaft should be lightly coated with the P/N 05083150AA grease, spread evenly on all splines without excess. The flywheel does not need to be removed for this repair. New clutch pressure plate to flywheel bolts P/N 06508880AA (quantity 6) must be used.
hard shift no I have not taken it to the dealer I waned to see if anybody else had problems so I would have some amo so they can't say it's normal thanks
