Auto Trans delay engaging
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by Jetranger, Nov 6, 2023.
  1. Jetranger
    Jetranger New Member
    Maryland
    I recently purchased a 2020 Challenger Scat Pack with 7,500 miles. I notice when I put the car in reverse, back up, then put it in drive......it takes 2-3 seconds for it to actually engage in drive. Anyone else experience this?
    Thanks !
    Jet
  2. Niles
    Niles Full Access Member
    Huntsville, AL
    Check your transmission fluid level. If your car did not include a dip stick you can purchase one from Amazon. It may simply be low. Changing out the filter and fluid may also correct the issue.
  3. HellKitten
    HellKitten Full Access Member
    NH
    I don't believe the newer. ZF transmissions have dip sticks. I have a 2020 with the 850re ZF no dip stick...
    It is very difficult to check transmission fluid level, even if you purchase a dipstick. This is because there is no way to ascertain fluid temperature. The correct fluid level is dependent upon the fluid’s temperature, which is not easily ascertained without a dealer scan tool.
  5. Jetranger
    Maryland
    Yeah....my car does not have a dip-stick. The trans temp seems to be good..... but the delay is a pain in the ___!
  6. Cloverdale
  7. SomewhereinTexas
    SomewhereinTexas Member
    Rio Grande Valley TX
    A slight pause going from reverse to drive is normal! Mine is a 21 and I've driven a few others and they have all been the same.
  8. Cloverdale
    And just learned about engine oil / trans fluid extractors which are inserted into engine oil dipstick tube and / or trans fill tube for fluid removal which my neighbor reports remove 100%.
