Can anyone help how to remove center brake light which is in the rear window ? I need it removed since I need to steal power cable.
Its very easy, the CHMSL(CENTER HIGH MOUNTED STOP LAMP ) is just held up there with push in clips mounted to the underside of the light housing. First you need to pull down on the black cover thats on the headliner, again it has its own push in clips mounted on the underside, just pull down and the clips will pop out. Then, all you need to do is grab the housing that extends over the window and pull down, the clips will pop out and the light will come down. No tools needed.
