Checking Transmission Fluid Level
Discussion in 'Challenger DIY/Tech Info' started by SRT-Tom, Mar 1, 2017.
Car Parts
    It is very annoying that our Challengers do not have transmission dip sticks to check the fluid level.
    If you want to do this yourself, you can buy a Dorman dipstick (Part #917-327) for about $20, on Amazon, or the Miller tool equivalent (Part #9336A). This, however, is not a permanent dipstick for your car. It is a measuring tool to check your transmission fluid levels.
    You will note that your transmission fill tube has a cap that reads, "For Dealer Use Only." Simply place a rag over the cap and gently grab it with channel locks to twist it out. Then after your engine warms up to 185 degrees, cycle your transmission through P - R - N - D just to make sure the fluid has circulated. Then add fluid, if necessary, to the targeted mid-range.
    After you complete this process, screw the threaded OEM transmission fill tube cap back on.
