Jalopnk.com had an article about the problem with chrome-capped lug nuts- a topic near and dear to Challenger owners. Here is an excerpt from the article: "Chrome-capped lug nuts look fancy in the dealership lot. But give them a few winters, and those same chrome-capped lug nuts can turn into little metal landmines just waiting to ruin your day. At their core, they're just regular steel nuts dressed up with a thin chrome cap. That two-piece setup might look slick, but it's also the perfect recipe for trouble. Over time, moisture sneaks into the tiny seam where the cap meets the steel. Once that happens, corrosion kicks in, causing rust to form underneath the shiny shell. Rust doesn't sit still. As it forms, it presses outward against the delicate chrome sleeve. The result? Swelling. A lug nut that once fit snugly with your socket has now ballooned into an unrecognizable and distorted version of itself. What starts as a cosmetic upgrade can become a structural liability. Instead of looking sharp, your lug nuts slowly morph into rust-filled, swollen obstacles. And when the day comes to actually remove a wheel- whether to fix a flat, perform your own brake job, add a wheel spacer, or just knock out some routine maintenance- you may find out the hard way that these capped imposters have betrayed you. The fix is pretty simple- ditch the chrome caps, please. One-piece lug nuts made from stainless steel or high-quality aftermarket alloys eliminate the weak seam that allows corrosion to form. Some automakers have shifted from lug nuts to lug bolts. However, plenty of vehicles are still rolling around with chrome-capped lug nuts. If you're not ready to swap them all at once, you should at least inspect your current set regularly. Look for early signs of swelling, rust, or flaking chrome. That said, the safest route is replacement, preferably before you're stuck on the side of the road with a wrench that no longer fits. The aftermarket has stepped up with plenty of solid options, from OEM-style stainless nuts to anodized aluminum upgrades that resist corrosion while still looking sharp. It's a cheap bit of preventive car maintenance that can save you hours of swearing, broken tools, or worse- an unsafe wheel on the highway. The truth is, chrome-capped lug nuts were a bad idea from the start. The only real solution is replacing them before they make your life miserable." The Problem With Chrome-Capped Lug Nuts
It is very important to have a good impact socket to fit the lug nuts most places hammer them on and the cap loosens from the lug it self and moisture gets in and you have a problem, all of my vehicles still have the original lugs outside my antiques . a torque wrench with a good socket helps also, We have a tool that will get any lug nut off when cap comes off. we hand torque every wheel we take off.
I won’t re-write the whole thing. See my story here: https://www.challengerforum.com/threads/best-lug-nuts.7234/page-2#post-42585
