Do you want a track-ready crate 392 Hemi for your old ride? This version of the 392 puts out 540 hp. with a carb. and 525 hp. with EFI. It's not a VVT and has a more aggressive cam profile along with forged internals. Selling price; $20,519.99 Specifications (carb. version) • Deep-Skirted Cast Iron Block with Cross-Bolted Mains • CNC Ported Aluminum Twin-Plug Cylinder Heads • Stainless Steel 2.100" Intake and 1.600" Exhaust Valves • Ovate Wire (Beehive) Competition Valve Springs • Viton Competition Valve Stem Seals • 279°/285° (duration @ .006") Hydraulic Roller Camshaft with 0.584" Intake and 0.552” Exhaust Lift • Forged Pistons (4.055" Bore) • 10.3:1 Compression Ratio • Aluminum Single Plane High Rise Intake Manifold with Holley 870 cfm 4-bbl. Carburetor (1) • 4140 Forged Steel Crankshaft – 3.795" Stroke • 4130 Forged Steel I-Beam Performance Connecting Rods – 6.200" Length • SFI-Approved Competition Crankshaft Damper • “Plug and Play” Wiring Harness • 80 mm manual throttle body (2) • Premium Tri-Metal Performance Engine Bearings • Precision Balanced Rotating Assembly • Distributorless Coil-On-Plug (COP) Ignition System https://www.classicindustries.com/product/mn1974.html
Wow!!!over 20K, like I got that laying around somewhere or buried out in the back yard.... Sent from my iPad using Tapatalk
And when you stop to consider that a 485 hp. 392 crate engine can be bought for only $9,054, with only 55 less hp. The extra $10K could be used for a lot of performance mods, like a supercharger. https://www.moparonlineperformance.com/product-p/68303090aa.htm
yeah, the later is more a possibility, and I still wouldn't do a supercharger. but would probably have to beef up the trans and axles. to handle the extra HP. 2009 stock RT stuff I think wouldn't survive the upgrades I think.
O.K. You lost me: Aluminum Single Plane High Rise Intake Manifold with Holley 870 cfm 4-bbl. Carburetor (1) 80 mm manual throttle body (2) That kind of like Megan Fox on the 1st Transformers?
The extra $ for those forged internals would support lots more boost if one's so inclined. I can only safely do 6 lbs on my 5.7 with the Magnuson!
