HID high beam on left side not working
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by Tennjaguar, Sep 26, 2022.
  1. Tennjaguar
    Tennjaguar New Member
    Hi, I hoping someone has run into the same problem. I have a 2010 SRT8 Challenger. When switching from low beam to high beam the left side will not go bright, it stays in low beam. I know, the first thing would be to just replace the HID bulb, but as you all know that’s not such a quick job or a Cheap job. The bulb runs about $100. In past when a car went from low beam to high beam the low beam would just shut off and that is why I’m asking any of you if you have run into the same problem. I tried to find a wiring diagram to see if my problem my just be a relay if there is a relay controlling the low/high beams. Any help here would be appreciate it.
    Thanks
    stingray likes this.
  2. 392hemiTA
    392hemiTA Member
    Louisiana
  3. 392hemiTA
    392hemiTA Member
    Louisiana
    Seems like the bulb, I thought when my passenger light went out I replaced the bulb from the wheel well turned light on still no light, come to find out it has a fuse for both, changed the fuse fixed it, I have a 2017 so don't know if it is the same
  4. fritzthecat
    Sunny Boca Raton
    Try RockAuto. I have the same car, a 2010 SRT. I had to replace a headlight bulb a couple years ago, it was less than $50.
