To install a MOPAR T-shifter (auto), just follow these easy steps: 1. Turn the car off. 2. Pop off the plastic chrome ring using a soft set of plastic tools or a screwdriver blade wrapped in masking tape. 2b. Take the clip out of the middle part to disengage the gears. 3. Put the shifter down to "Drive" area. 4. Pop off the stock shifter. It will just slide off the rod. 5. Put your new MOPAR T-shifter hifter on and tighten up the allen screw with an allen wrench. 6. Replace the clip, reinstall the ring and you are done! Try to keep the shifter straight or it could come loose on you.
