Most vinyl wraps only last 5-7 years. That's why most guarantees are only for 5 years. In order to increase its lifespan expectancy and minimize the risk of damage, consider these tips to help it last longer and look clean and polished: Buy a premium wrap and have it installed by professionals. Wash your vehicle regularly: Keeping your vehicle clean can help prolong the lifespan of your wrap. While you can bring your vehicle to the car wash, hand-washing your vehicle is a gentler option for your vehicle and wrap. If you can remove grime and dirt with a simple hand-wash, this is typically better than bringing your vehicle to a car wash, which may be too rough and damage your vehicle. Avoid high-pressure hoses, as these can tear or damage your wrap. Minimize exposure to the elements: Hot temperatures, cold weather and ultraviolet rays contribute to wear and tear on your vehicle, making where you park your vehicle incredibly important. Ideally, you should park your vehicle in a personal garage that blocks sunlight and inclement weather. It helps if this garage is also temperature regulated because hot temperatures can cause various complications with vinyl adhesive. Immediately remove stains and spills: Spills or droppings can stain immediately, meaning the longer you let them sit on the wrap, the more difficult it is to remove them safely and effectively. Bird droppings are a common issue that can cause permanent damage to the wrap if not removed quickly. You should also clean fuel or gasoline spills immediately, as these can degrade the vinyl and lead to permanent damage. While cleaning your wrapped vehicle, avoid oil-based solutions. Dry your vehicle after washing: While many people people prefer to let vehicles air dry, vinyl wrap is not hydrophobic. It absorbs a large amount of water, which can leak into the adhesive and make it less effective. Drying your vinyl sooner with high-pressure air or a dedicated microfiber cloth is better. Use the right products: While vehicle enthusiasts often buy specialty products to care for their car and wrap, not all products are created equal. Choosing the right products can protect your vinyl and prevent future damage. How long your vinyl wrap lasts will also depend on the products you use. Never use solvents, oven cleaner, orange oil, kitchen and bathroom cleaners, oil-based cleaners or engine degreaser on your wrapped vehicle.
Any advice when vinyl wraps are on\with Ceramic Paint? Does Ceramic paint change anything with the above list?
