How to replace Key fob Battery for your challenger
Discussion in 'Challenger DIY/Tech Info' started by SRT-Tom, Feb 15, 2012.
Car Parts
    If your key fob battery dies, it can be easily replaced.
    Here are the steps:
    1. Slide the button and remove the metal "emergency
    key."
    2. Use the blade of the key (or small flat screwdriver blade) at that end to carefully pry the two fob halves apart (they have snap tabs) by working around the both sides to separate top and bottom halves.
    3. Remove the old battery and replace it with a single disc battery- IIRC a CR2032 (or equiv.). Note: Hold the battery around the edge to avoid contamination.
    4. Line the cover back up and snap the perimeters all around.
    5. Re-insert the blade key until it clicks back into place.
    (Note: Re-programming is not necessary).
      File size:
      79.5 KB
      10
  2. Storm Rider
    That sounds easy enough. Thanks.
  3. heminit
    heminit Full Access Member
    Central Arkansas
    Great info, thanx for posting!
  4. walnetto
    walnetto Full Access Member
    Wisconsin
    Yeah, these new fobs seem to eat up batteries. I am only two years old and my fob seems to be fading. I am using the second one and it seems to work better and from a greater distance. Lots of guys on CT are complaining that they had to change their batteries already. My old 2001 and 2002 and 2003 fobs went forever. Progress.
  5. Janning
    Janning Full Access Member
    Ok, I should have been more specific. What if Fob battery dies and I'm out in the middle of nowwhere, its 2am and I don't happen to have a replacement battery on me?
    -thnanks James
    Read your owner's manual.
    It says to take the nose side of the fob, on the side opposite of the emergency key, and use it to push against the start button.
    The start button will recognize the fob even though the battery is dead and will start the car.
    If the car is locked, and the remote entry doesn't work because the fob is dead, use the metal emergency key to open your door.
