IN SEARCH OF........
Discussion in 'Challenger R/T Engine & Performance Modifications' started by IntimidatorRT, Dec 27, 2019.
  1. IntimidatorRT
    I have an 2009 RT with the 5.7 and just bought a 6.1L intake. I need the stock fuel rails for that intake. I looked on the Rock Auto site and don't see them listed. The guy I bought the intake from game me some after market rails but they wont work with my shaker mount. If you know the part numbers and such.....
    so any help will be appreciated.
    I looked on my 6.1 hoping to find a pn tag,
    but sorry, no luck
    Mopar Wholesale Parts lists the part number for the 6.1 fuel rail as: 5037480AA
  4. IntimidatorRT
    THANKS!! MUCHO GRACIAS!!
  5. IntimidatorRT
    Just want to let you know. Good luck finding this part at a parts house or dealership.... out of stock to discontinued. Which means. If it goes bad or needs replacing, you have to go after market,... good thing is, the guy that sold me the intake actually found one at one of his buddy’s speed shop and is getting that for me...
    Another option would be to buy the OEM fuel rails from an auto salvage company. There are several national databases on line.
    If you prefer after market fuel rails, there are several available. Some are actually an upgrade that can increase the amount of fuel that the fuel injectors have to draw from. Also some come with pulse dampers that can reduce the effects of engine harmonics/vibrations on the fuel injectors. Here is a link to one:
    https://www.a2speed.com/c-272-hemi-fuel-rails.aspx?manufacturerid=42&startPrice=0&endPrice=0
    IntimidatorRT likes this.
  7. IntimidatorRT
    That I know. But they will not fit with the shaker as the mounting tabs are too thick and will make the shaker hit the hood. That’s why with the stock ones they just have a thin metal tab to mount with. The intake I bought had after market hi priced ones. Too thick where the mounting points are.
  8. 2017 Redline HC
    Is there any way to modify either the shaker or fuel rail mount to make up the difference?
  9. IntimidatorRT
    Can’t modify the shaker mount. But was looking at grinding down the tabs to make them thinner, but since I did find a set of the stock ones, I won’t be doing any grinding..
  10. B5blueRT
    It's at times like this that I step back, dig way down into my tool box and pull out the only two solutions left:
    Velcro (for "needs to be removable") and Duct Tape (for "no need to remove"). ;)
