That is how I lost my '67 Charger. Was teaching an EX-Girlfriend to drive on a back, gravel road and was too much power for her. Back in the '70's, LSD wasn't Computer Controlled, and mine would CHIRP when going around corners. More of a Spool, than limited-slip so when the thing started Fishtailing, she turned the wrong way, spun in circles and went off a 20' bank. Tow truck pulled it back up on the road and I trove it home
On my '96 XJ I installed an Auburn HP LSD in the rear axle and it worked AWESOME. if you made a normal turn it was like an Open Diff, but if you gave a lot of fuel it would turn both tires. The more pressure you applied the tighter it got. Great unit!
