Needing Struts for a 2018 Challenger GT AWD
Discussion in 'Dodge Challenger General Maintenance' started by SouthernGypsy, Feb 14, 2026.
  1. SouthernGypsy
    SouthernGypsy New Member
    Arkansas, USA
    I need front Struts for my 2018 Challenger GT AWD.
    Problem is that when I call parts stores they try to sell me struts for 2009-2020 models and I didn't think the AWD used the same struts as the RWD models and I certainly know where was not AWD Challengers back in 2009...
    I tried web searches but same kind of results everything just shows results for RWD models.
    Does anyone know what brands/models/part numbers of struts fit the AWD models?
    Try the Mopar store or contact Luke at Steve White Motors.
    Search Results | The Official Mopar eStore
    Digital Showroom | Steve White Dodge Chrysler Jeep Ram FIAT
  3. SouthernGypsy
    Arkansas, USA
    Does anyone know if the Right and Left side use the same part number?
    I finally found a part number that says it's for the AWD models but it says "Left", but there is no listing for the "Right".... and when I look at the picture I don't see why it would make a difference since the part numbers are only for the strut cartridge itself (not a complete assembly with the springs and forks, I can see where that would make a difference left and right but not the cartridge only yet they are all marked Left with no sign of a part number for the Right).
    I will get you the part numbers.
  5. HellKitten
    HellKitten Full Access Member
    NH
    Unfortunately there is very little in the aftermarket for front struts on the AWD Challengers and Chargers.
    You have obviously the OEM which I believe they are made by Sachs. Then there is KYB & Monroe and a few no name brands so far
    I have a 2020 AWD Challenger so this has crossed my path as well. I did replace the rears with Bilstein , not knowing where I purchased a set of four shocks on line that the dipshits didn't realize that Bilstein doesn't make the front one yet, though I am hoping soon.
    If you're into lowering your Challenger I did see a few companies that make coilovers where you buy a matched set of four.
    Hopefully this helps a little..
    I contacted Steve White Motors. It needs your car's VIN number to identify the correct part. I can forward this information to Luke for you.
