1. 13OrngChallRT
    I have tried everything I can find in here and I still have no heat. A few weeks ago we had a cold snap and I ran it a couple days. Then a few days ago I switched things over and it's like the air is still on. I ended up buying one of those dash mounts so I can see in the mornings. The rear window fogger switch was flashing each time I started my car so I pulled the fuse. That didn't help, so I unhooked the negative battery terminal for 5 minutes. That stopped the flashing, but still no heat. The blend doors aren't making any unusual noises. The thermostat is working, the heater core hoses are warm/hot, there is plenty of antifreeze. I'm stuck, at least my butt is toasty from my heated seats.
    Mopar or No Car, Sent from my Moto G Play using Tapatalk
  2. Billy
    Billy New Member
    I had the no heat thing too on my 2014 RT. Disconnecting the battery and holding the cables together for 2 minutes fixed mine the next day. Stupid problem for new cars
  3. 13OrngChallRT
    Holding the cables together??
  4. Billy
    Billy New Member
    Yeah. Run the car and turn the temp on high from hot to cold on full blast a few times. Turn off the car and disconnect the cables and hold them together for a couple minutes. Go to bed and pray . Mine just worked the next morning. Good luck man
  5. 13OrngChallRT
    Alright, tried that with no luck also btw once you unhook the battery. Don't close the trunk, especially if you're fat with short arms. I had to rig a hook on a pole to reach my inside trunk release. What a pain in the ass. Tried jumping with wives car but no luck.
  6. 13OrngChallRT
    Took my car in, it was the blend door actuator I wished I was more bendy so I could have fixed it myself. Of course they wanted to upsale this and that.
  7. Billy
    Billy New Member
    How much did that cost?
  8. 13OrngChallRT
    They aren't done yet, will let you know later
  9. 13OrngChallRT
    Picked car up last evening, with oil change, tire rotation, new blend door actuator out the door for 230. If I hadn't torn my rotator cuff and had more mobility I could have done the work myself. Always feels good to get back in my own car. I do love my wives 200 but it's not my Challenger. Oh and the heat does work superb.
  10. Billy
    Billy New Member
    Heat stopped again. Hope it’s under warranty . Plus my key fob is acting up
