1. From RUSSIA
    From RUSSIA Member
    Russia, Sankt Petersburg
    Hi guys! need help with a question- what kind of oil do u use in E 3.6L? And what kind of oil need to use of plant manufacturer? i check that oil need to use 5W -30. Do u know anything about what king of firm oli(mopar,mobil,shell) need to use??? Whats is the best one? What about mineral,full synthetic or semisynthetics?
    Thanks a lot for help
    hi from Russia ;)))
  3. From RUSSIA
    From RUSSIA Member
    I know it. what kind of oil flooded into the engine from the factory Dodge? (When you buy a new car).
  4. From RUSSIA
    From RUSSIA Member
    mineral or polusentetiku? I understand Mopar 5w-30?
    The 3.6 motors come with standard non-synthetic oil from the factory. I'm not sure about the brand. MOPAR does not have its own brand of oil, just filters. My 6.1 SRT came with Mobil 1 full synthetic.
  6. From RUSSIA
    From RUSSIA Member
    Standard Oil is a mineral?
  7. From RUSSIA
    From RUSSIA Member
    after buying a car where you have it serve? the dealer? I understand that everyone decides for himself what kind of oil to pour.
  8. SRT-Tom
    The standard fill on most car engines, like the 3.6, is conventional oil. This is the least expensive oil and it should be changed every 3,500 miles or 4 months, whichever comes first.
  9. SRT-Tom
    Many Challenger owners, like myself, change their own oil. We do it to save money and make sure that it is done correctly.
    If you take your Challenger to a dealer, it will replace the conventional factory oil with a similar conventional oil. If you want synthetic oil, they will gladly install it but you will pay three times the amount.
    Synthetic has three advantages, however:
    1. It provides ultimate protection for high performance engines, like my 6.1 Hemi.
    2. It only has to be changed once a year.
    3. It can provide better mileage and slightly more horepower because of less friction in the engine.
  10. From RUSSIA
    From RUSSIA Member
    means that conventional oil? mineral or cheap polusentetika?
