1. RT PLUS
    RT PLUS New Member
    Just bought an R/T. Anyone know when a programer is coming out for this year? Lastly, will the sportline kit by Eibach work on my 2012 Hemi?
  2. batman69
    batman69 Member
    Rockland county NY
    I have a brand new in the box never opened eibach pro kit lowering springs part#2895.140 find out if it fits your car asking $225 obo
  3. HemiGpa
    HemiGpa Member
    Huntington Beach, Ca
    No word on being able to tune the 2011 and 2012's yet, Diablo is trying to crack the codes but Dodge is now using a rotating code of some kind.
    as for the Eibach kit you have to change your upper control arms to an after market set up to be able to align the front wheels correctly....This is something the Eibach website fails to mention.
    One of the guys in my club found this out the hard way when his car was all torn apart to lower.
    Hope this helps
  4. AZ MSCL
    AZ MSCL Member
    Scottsdale, AZ
    You will need a front adjustable camber kit to add the lowering kit (any kit), Eibach and others sell these kits and they run around $300. Been there, done that. Just make sure you get the kit for the front because they sell kits for the rear which are much cheaper (unlikely you will need a rear kit). I would get one that is adjustable +/- 1.5*. If you don't install the camber kit, the tops of your tires/wheels will be canted in towards the engine (camber).
    As for the tuner, it may never happen. Hate to be negative but this is a real possibility. Arrington does a ECU/harness kit from a 2010 for around $1,000 (I think). B&G Performance can sell you a pre-programmed ECU (based on your existing mods) or you can send them your ECU and they will flash it. It will only work for current, installed mods and cannot be changed if you add new mods requiring tuning (have to do it all over again). About $1,000 if they supply the ECU and about $350 if you send them yours. The Arrington option may work the same way as the B&G setup, not sure.
  5. ZEN357
    Diablo Sports Trinity Model.
