Sequential Tail Lights
Discussion in 'Challenger Exterior Modifications Forum' started by Storm Rider, Sep 18, 2011.
  1. Storm Rider
    I have added sequential tail lights to my Chally and here are a couple of vids. You may have to click on them to make them work.
    [/SIZE]
  2. BIRDMAN
    BIRDMAN Full Access Member
    How did you do that?
  3. Storm Rider
  4. 2009SE
    2009SE Active Member
    NW Arkansas
    Be sure you get a sequencer kit that
    does not put the load of the extra 4
    bulbs on the InterConnectModule.
    Most of the kits time out after a while and stop
    sequencing the 2 inner most bulbs to help with
    the ICM overheating/burnout problem.
  5. wesalbert
    wesalbert Full Access Member
    Who's sequencer do you recommend?
    Also looking at your sig, what is the NoESP mod? Got a link?
  6. 213Auto
    Collegeville, PA
    We sell the Webelectric Brand and have had great results.
    Here is some info for their product,
    "Plug-N-Play" Installation Smart-Sequence Technology
    Auto-Adjust Circuitry No Fixture Modification Required!
    The STS-4CHSS Sequential Turn Signal kit will convert the taillights on your 2008+ Dodge Challenger into Sequential Turn Signals.
    This is a true Plug-N-Play kit. You do not have to break off any rivets. There is no need to go into the fuse box to make any connections. Return to stock at any time without any evidence of ever being there! The kit contains pre-wired, plug-in harnesses that install with no wire cutting or splicing of any kind. (Note: 2011 cars may need one ground wire splice) *
    With Smart-Sequence technology, your tail lights sequence ONLY when a signal is on. When you hit the brakes, all lamps come on together. (click here for more info)
    Plus, these harnesses feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, our electronics sense your car's flasher speed and adjust the sequence timing for you.
  7. Shaggy
    That is bad ass Storm! Love that look!
  8. 2009SE
    NW Arkansas
    Google NoESP.
    I got it online.
    It disables the ESP at a touch.
    Its kick arse...
    http://www.zautotech.com/products.html
    This info is all over the other Challenger Forums.
    Old news but new news round here.
    Maybe I need to start a NoESP post...
    I have WebWElectric but they are heavily modified by
    me to keep the extra bulb load off the ICM and the
    time out feature has been disabled in the PIC Logic.
  9. Shaggy
    Start up that NoESP thread here 2009! :waytog:
  10. wesalbert
    2009SE, wouldn't an easy solution be to use LED tail lights with the sequencers? That would solve the load issue as well, wouldn't it?
