Service Keyless System
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by fritzthecat, Nov 14, 2023.
  1. fritzthecat
    Sunny Boca Raton
    Today I got a message on the dashboard display “Key Fob not Detected”. Couldn’t start the car with the push button. Temporary solution was to pop the button cover off, then you can put the key fob into the slot and turn it like a regular key. Thought maybe it was the fob, but a new battery didn’t help, and I tried my other fob and that didn’t work either. The message that comes up now, after starting the car with the fob and turning it off, is “Service Keyless System”.
    I found a TSB that has that error message listed, #08-047-11 …. (DTC) B25AA-01, B25A9-01, but it seems to be for a 2011, and talks about replacing both door handles with something about the proximity entry system, which my 2010 doesn’t have.
    So I have to admit, I’m stumped. Has anyone else run into this problem before?
    Take your car back to the dealer and show them this RRT number: RRT 10-022.
    April 19, 2010
    TO: ALL DODGE, CHRYSLER AND JEEP DEALERS
    SUBJECT: RAPID RESPONSE TRANSMITTAL #10-022
    Flash: WIN Module (Intermittent FOBIK Functions)
    INVOLVED VEHICLES:
    2010 (DJ/DS) RAM Truck
    2010 (JC) Journey
    2010 (LC) Challenger
    2010 (LE/LX) Charger/300
    2010 (WH/WK) Grand Cherokee
    2010 (XH/XK) Commander
    NOTE: This Service Action affects unsold vehicles.
    NOTE: The VIN List is available on DealerCONNECT for all affected dealers. The VIN List has
    been inserted in the Service Tab under Rapid Response Transmittals. The dealers receiving
    the Rapid Response Transmittal Service Action are the “Ship To” dealers and the VIN’s listed
    are specific to their dealership. All involved vehicles will be loaded into the VIP system.
    NOTE: This should be a top priority and be completed prior to sale to avoid suspect vehicles
    being delivered to customers.
    DISCUSSION:
    A number of vehicles, equipped with FOBIK may have intermittent operating characteristics. Dealers
    are required to verify the manufacture of the Wireless Ignition Node Module (WIN) and if necessary,
    Flash the (WIN) with updated software.
    INSPECTION PROCEDURE:
    1. Using the wiTECH Diagnostic Application verify the WIN module is manufactured by
    Marquardt.
    A. Click on the reports tab on the top of the main page.
    B. Select Run/View Reports.
    C. Select ECU Details report.
    D. Click on the arrow key to run the report.
    E. Scroll to the bottom to find the WIN section.
    F. Look at the supplier ID is the Supplier Marquardt?
    a. NO – Repair is complete return vehicle to inventory.
    b. YES – Continue with the repair procedure.
    2. If supplier is Marquardt, check the software version listed on the same page. Is the WIN
    software version lower than 10.02.01?
    A. NO - Inspection is complete return vehicle to inventory.
    B. YES - Continue with the Flash repair procedure.
    Form DMAIL-001 REV 1.01
    FLASH REPAIR PROCEDURE:
    NOTE: If this flash process is interrupted/aborted, the flash should be restarted.
    3. Using the wiTECH Diagnostic Application, flash the WIN. For instructions select the “HELP”
    tab on upper portion of the wiTECH window, then “HELP CONTENTS.” This will open the
    Welcome to wiTECH Help screen were help topics can now selected.
    4. After reprogramming clear any DTC's that may have been set in other modules due to the
    reprogramming. The wiTech application will automatically present all DTC's after the flash and
    allow the tech to clear them.
    5. The software level will be updated to 10.02.01 in the WIN module.
    POLICY: Reimbursable within the provisions of the warranty.
    NOTE: USE OF THE LABOR OPERATION INCLUDED WITH THIS SERVICE ACTION ON
    VEHICLES OTHER THAN THOSE INVOLVED MAY BE SUBJECT TO CHARGE BACK.
    TIME ALLOWANCE:
    LABOR OPERATION NO:
    18-80-32-95 Inspect for Supplier of WIN 0.2 Hrs.
    18-80-32-96 Inspect and Flash WIN Module (C) 0.2 Hrs.
    International Related Operation
    18-00-00-WT StarMOBILE (International) (C) 0.2 Hrs.
    FAILURE CODE: FM – Flash Module
  5. jdwilliamson
    jdwilliamson New Member
    Stantonville, TN
    Howdy y'all,
    I'm getting the "Service Keyless System" message, along with intermittent "Keyfob Not Detected" messages on my 2014 SXT. Additionally, the fob still unlocks and re-locks the doors, but the lock button on the outside door handle along with the unlock sensor on the underside of the outside handle no longer work. Or rather...they weren't working, but were and are when I checked it again just a few minutes ago. The messages appear to be gone now, too. We had a torrential rainfall last week, after which I found the driver's side floorboard completely saturated, along with the above mentioned issues. I know...two separate problems, but I'm wondering if something behind the dash might have gotten wet and caused this behavior, and has since dried and returned to normal operation. Any ideas?
  6. Sexy Blue
    Sexy Blue AKA Bob
    Hudson Valley, NY
    I would fold down the back seats and put a dehumidifier in the trunk. Been there, done that.
  7. NinetyO
    NinetyO Member
    Tennessee
    Did the seal around your door start leaking? Mine did this all of a sudden in a torrential rain. After that it just kept happening and they put some really gross black goo all under my door seal then replaced it. In summer I can wipe it off with a cloth as it gets melty. And it leaves my car window filmy in rain but Windex removes it.
    Was there another design flaw? Mine made my headliner wet and dripped from there. The goo..whatever it is, stopped it. I was very worried about water shorting something out. Lucky this was summer and the heat baked it dry the next day with windows open. I'm also all leather so that helped.
