Speaker replacement
Discussion in 'Challenger Audio/Video/Electronics Modifications' started by adammcurrie, Sep 8, 2015.
  1. adammcurrie
    adammcurrie New Member
    So I decided to replace the stock Alpine with some Rockford's
    ImageUploadedByTapatalk1441725495.476837.jpg ImageUploadedByTapatalk1441725503.625849.jpg ImageUploadedByTapatalk1441725511.177188.jpg ImageUploadedByTapatalk1441725517.445421.jpg
  2. Dakota21601
    Dakota21601 Member
    Greenwood, IN
    Nice. So. Hows it sound?
  3. adammcurrie
    Sounds good, although 8in sub provides some bass a 10in would be better
  4. kiss1962
    kiss1962 Member
    Canada
    Ive replaced the factory 6x9 door speakers with some JBL GT7-96
    I would like to put a pair in the back too.
    and with a sub would be nice
    I see in your pictures they look like 6x9s ...Are those 6x9s in the rear deck too?
    Because every one says there only 6.5" speakers in the rear deck?
    Please help clarify the mystery...
    Did you have to cut that hole for the 8" Sub or is it factory?
    I think with a 4 channel amp wired mono to the sub and stereo to a pair of rear deck speakers would sound Awesome.Please respond !!
  5. adammcurrie
    So for my 2015 I have following
    Door panels (2) 6x9
    Front dash (3) 3.5in
    Rear deck (2) 6.5in and (1) 8in sub w/o enclosure
    (2) Rockford amps (1) for door, dash and rear deck and (1) for sub and both amps are tied to LC7i audio controller
    They did not have to cut anything for the Sub but could not fit an enclosure like originally hoped so it is open air flow. Decent amount of bass but there are some frequencies it just can't handle
    Hope this helps
  6. ChallengerRT
    ChallengerRT New Member
    Miami Fl
    Hello everyone, I'm new here and I need a little help, I have a dodge challenger R / T 2017 and I want to change the whole audio system, so little research, the car has 6 speakers of which I only find 4, in the doors and in the front. my intention is to change all the most powerful speakers and a pair of subwoffe 12 "with a good Amp. Can you give me some idea, like brand, model. Thank you
  7. ZEN357
    Wheeling, WV
    Nice job! Hope they sound good!!!
  8. IntimidatorRT
    you should have 2 speakers in the back deck. also the amp is located there too.
  9. synoptic12
    synoptic12 Full Access Member
    * Quite a task. You must have the B.A. 6 Speaker set-up as I. You should be aware that the B.A. System is a 2 OHM impedance, not 4 Ohms. The 2 Ohm provides more power but the separation is not 'stereo'; mostly monoaural. I was a radio tech for some time (trouble shooter). There is a great deal to contend with. I researched for over six months and decided to leave the system alone. Naturally, if you are inclined, be prepared to make a huge amount of changes. If you have sirius, that poses another issue as all electronics are tied into the steering wheel. There are far too many variables and the cost is not worth the effort.
    Know what you're getting into before jumping the gun.
