Stealth side mount subwoofer enclosure
Discussion in 'Challenger Audio/Video/Electronics Modifications' started by IMCHALLENGED, Apr 20, 2017.
  1. IMCHALLENGED
    IMCHALLENGED Member
    Here is my new prototype subwoofer enclosure build for my challenger. Previous I did a all in one solution, which used a built in amplifier. Due to availability and performance of the amp I decided to go in another direction. With this enclosure it will have a 1cu ft of air space to accommodate most 12" subwoofers. Mounting depth is around 7". The subwoofer I will be using in this build will be a Helix E12W 12" subwoofer. Its a sound quality sub that has a shallow mounting depth of only 3.5". Ive done these subs in other installs with the 8" and 10" with decent output. So the E12W should perform well. Also since its a slim sub I will save on weight.
    Test fitting the subwoofer
  2. redbullssg
    redbullssg Active Member
    Looks nice so far
    2014 Challenger R/T Blacktop Edition
    CAI, Long tube headers and full Pypes Violator system, Diablo Trinity, Innovate wide band, catch can, Mopar strut tower brace, BC Racing Coil Overs, full Hopnot kit.
    Jackson, Michigan
  3. chithead
    chithead Full Access Member
    Landis, NC
    Very nice, and great choice of subwoofer as well! The Helix E12W is by far one of my favorite shallow subwoofers.
  4. redbullssg
    I'd like to see the end result....
    Jackson, Michigan
  5. IMCHALLENGED
    IMCHALLENGED Member
  6. IMCHALLENGED
    IMCHALLENGED Member
    Alright finally got the grill mesh in today, so I pressed a custom grill to fit the trim. I did another trim ring as well. I wrapped this one in suede instead of vinyl. This give the enclosure a very stealth look. No sub woofer showing, just a very clean oem look.
  7. IMCHALLENGED
    IMCHALLENGED Member
  8. chithead
    Landis, NC
    Very good work!
