Hello guys I have 2016 dodge challenger shaker 392 recently I have started hearing a rubbing / squeaky sound when making hard turns such as if I go in a parking lot and turn the wheel hard and just slowly drive In a tight circle it will have a constant groan sound and it will change tones and even vibrate at one point and I can’t pinpoint if it’s coming from front or rear any help ? Sent from my iPhone using Tapatalk
Have you checked the level of your power steering fluid? If it is low, top it off and monitor for a leak. If that doesn't fix the problem, your power steering unit may need to be replaced.
Your 392's electronic steering may have a bad gear. See if it sounds like this sound clip: A Noise An Electric Power Steering Gear May Make When Bad
Ok perfect where do I find the reservoir so I can check and monitor for any leaks I’ll do that first Sent from my iPhone using Tapatalk
Electronic steering does not use hydraulic fluid. Electric Power Steering in Dodge Challenger: What You Need to Know - Skills-ware How Electric Power Assisted Steering (EPAS) Works, And How It Compares To Hydraulic | CarThrottle
My phone won’t let me send the video on here is there any other way I can send you it? Sent from my iPhone using Tapatalk
