TR-6060 Gear vs Speed
Discussion in 'Dodge Challenger General Discussions' started by Farmer Fran, May 15, 2021.
  1. Farmer Fran
    Earth
    Anyone have the gear vs speed chart for the 2021 (392 Scat Pack?) my search FU is terrible.
    390 final?
    Thanks,
    Fran
  2. Wizard of Iz
    Sending you some info. But not exactly what you want.
  3. Farmer Fran
    Earth
    Thank you. After looking at the chart, I came up with this; I was looking for the "maximum" speed in each gear (1 through 4) for shifting, up or down.
    Assuming the TR-6060 in the 2021 392 Scat Pack is
    Gear Ratio Calculator (tremec.com)
    3.9 Final
    TR-6060 Gearing
    1st = 2.97
    2nd = 2.10
    3rd = 1.46
    4th = 1.00
    5th = 0.74
    6th = .05
    R = 2.90
    Tire height of 28.4" (305/35-R20)
    6000 RPM
    1 = 44
    2 = 62
    3 = 89
    4 = 130
    6400 RPM
    1 = 47
    2 = 66
    3 = 95
    4 = 139
    Wizard of Iz likes this.
  4. TRCM
    TRCM Full Access Member
    Southeast VA
    That tire size only comes on the widebody version of the scat pack....
  5. Farmer Fran
    Earth
    This is true but the only thing that matters is the tire diameter
    So if you are running the 275/40-R20 the math is about the same. Less than or about 1mph.
    Darrell Feit likes this.
  6. TRCM
    Southeast VA
    true, as long as the tire height is the same
  7. Farmer Fran
    Earth
    They are 28.4 vs. 28.6 -- but each person would have to do their own math
  8. Darrell Feit
    Darrell Feit Member
    Green Bay, WI
    My 2021 Scat Pack has 275/40R/20 on the rear. The speedo shows the identical speed as the Garmin Navigation unit.
