TSB /Recall/RRT Lists (2008-2014)
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by SRT-Tom, Nov 4, 2023.
    Here are lists of the past TSBs, Recalls, Rapid Response Transmittals and Customer Satisfaction Notices for the years 2008-2014. (Note- Links no longer work).
    TSB Date .. Model Yr … TSB # …............................ Description......................
    07/17/14 … 1214 … #18-056-14 …. This bulletin involves replacing the Amplifier if required (SRT only)
    07/15/14 … 1314 … #18-034-14a .. P0520- Engine Oil Pressure Sensor Circuit
    05/09/14 … 1114 … #08-024-14 …. RHW RHP Radio Software Enhancements
    04/15/14 … 0814 … #22-002-14a .. Tire Flat Spotting Identification, Prevention and Resolution
    04/02/14 … 2014 … #18-027-14 …. Flash: Powertrain System Improvements/Enhancements
    03/11/14 … 2014 … #18-015-14 …. Flash: Malfunction Indicator Lamp (MIL) Illumination. Includes Various Driveability Improvements (5.7L)
    02/19/14 … 0814 … #22-001-14 …. Steering Wheel Vibration at Highway Speeds
    02/13/14 … 2014 … #19-002-14a .. Steering Column Squeak / Moan While Turning Wheel (5.7L models)
    12/10/13 … 2014 … #18-053-13 …. Flash: MIL Illum. P0606- Internal Control Processor / Auto Oil Change Indicator Accuracy (3.6L)
    11/09/13 … 1314 … #08-087-13 …. Flash: Audio Enhancement, Reduce Audio Distortion
    10/19/13 … 2012 … #08-070-13c .. RHR RHW Or RHP Radio Navigation Map Enhancements
    07/30/13 … 2013 … #08-056-13a .. Flash: Cluster Incorrectly Displays Suspension And Shifting Track
    06/11/13 … 2013 … #08-043-13 …. Flash: SRT Auto Transmission, Adding Launch Control Feature
    06/11/13 … 2013 … #08-046-13 …. Flash: SRT Manual Transmission, Adding Launch Control Feature
    05/15/13 … 0910 … #18-021-13 …. Flash: Performance Derate Above 55 MPH Immediately After Start-Up When Accelerating At WOT
    05/14/13 … 0811 … #08-035-13 …. Flash: SRT Subwoofer Thump Noise After Vehicle Is Turned Off
    05/11/13 … 1213 … #08-033-13 …. Flash: Two Or More Speakers Will Mute When Playing Certain Media Sources
    04/20/13 … 1113 … #23-016-13 …. Driver And/Or Passenger Seat Fore/Aft Movement During Acceleration And/Or Braking
    03/29/13 … 2012 … #08-021-13 …. Flash: Hands Free Module Customer Satisfaction Enhancements
    03/06/13 … 1112 … #18-010-13 …. Flash: MIL Illumination P0340- Camshaft Position Sensor Circuit - Bank 1 Sensor 1 (5.7L/6.4L)
    02/27/13 … 2013 … #23-011-13 …. Passenger Compartment Odor
    02/12/13 … 2013 … #18-007-13 …. MIL Illumination P0300 and/or Engine Runs Rough With Factory Fill Fuel
    12/20/12 … 2012 … #08-065-12 …. RHR Navigation Map Enhancements
    12/15/12 … 1112 … #18-031-12a .. Flash: MIL Illumination P0108 - Manifold Absolute Pressure Sensor Circuit High
    11/15/12 … 1113 … #08-053-12 …. Flash: RHR, RHW Or RHP Radio Software Enhancements
    10/30/12 … 2012 … #08-050-12a .. Flash: Hands Free Module Prompts Begin To Play Without Pressing Phone Or Voice Recognition Button
    10/30/12 … 2012 … #17-002-12 …. Incorrect Rear Ride Height
    09/21/12 … 2013 … #07-004-12a .. Attention! Release Of New Engine Coolant Organic Additive Technology (OAT)
    09/14/12 … 1112 … #23-028-12 …. Headliner May Droop 1/4" (6mm) to 1/2" (13mm) At Rear Edge Of Power Sunshade Opening
    08/06/12 … 2012 … #08-050-12 …. Flash: Hands Free Module Prompts Begin To Play w/o Pressing Phone Or Voice Recognition Button
    07/06/12 … 0912 … #03-001-12 …. Rear Axle Gear Whine
    02/16/12 … 0912 … #22-001-12 …. Chrome Clad Wheel Adapters For Proper Balancing
    02/09/12 … 2012 … #18-008-12 …. Flash: MIL Illumination P0441 - Evap Purge System Performance
    01/10/12 … 0812 … #23-003-12 …. Light To Moderate Paint Surface Imperfections On Factory Applied Paint Finish (revised 02/07/12)
    10/26/11 … 2011 … #08-036-11a .. Audio Device Compatibility Issues Including iPod and iPhone
    10/18/11 … 2011 … #22-005-11 …. Chrome Wheel Delamination
    10/18/11 … 2011 … #18-033-11a .. Flash MIL Illumination P2097 And/Or P2099 (6.4L)
    10/06/11 … 2011 … #23-039-11 …. Door Smart Glass Self Cycling And/Or Battery Drain
    08/20/11 … 2012 … #08-051-11 …. Radio Anti-Theft Codes - 2012 models
    08/10/11 … 0811 … #23-031-11 …. Outer Door Belt Weatherstrip Cracked And/Or Drooping Down
    08/06/11 … 2011 … #08-047-11 …. (DTC) B25AA-01, B25A9-01, Service Keyless System Message, Or Passive Entry Door Handle Inoperative
    06/29/11 … 2011 … #08-036-11 …. iPod and iPhone Compatibility Issues
    06/24/11 … 2011 … #18-033-11 …. Flash MIL Illumination P2097 And/Or P2099 (6.4L)
    06/24/11 … 2009 … #18-032-11 …. Flash: MIL Illumination For P2181 - Cooling System Performance
    06/21/11 … 2011 … #25-001-11 …. Incorrect Positive Crankcase Ventilation Valve (PCV) Installed (6.4L)
    06/16/11 … 0910 … #18-031-11 …. MIL Illumination for P0128 - Thermostat Rationality
    05/19/11 … 2011 … #08-024-11 …. Flash: Intermittent No Start Or Intermittent RKE Function
    05/05/11 … 2011 … #08-020-11 …. SiriusXM™ Travel Link™ Update Policy
    05/03/11 … 2011 … #23-017-11 …. Missing T-Handle Shift Knob, Pedal Kit, Floor Mats, Car Cover And Door Sills
    04/18/11 … 2011 … #18-020-11 …. Flash: MIL Illumination And Driveability/Transmission Improvements
    04/06/11 … 2011 … #08-015-11 …. Loss Of Communications With HFM
    03/29/11 … 2011 … #18-018-11 …. Flash: MIL Illumination For Any P06DD, P0522, P0108, P1239 (3.6L)
    03/15/11 … 2011 … #08-002-11 …. Decklid Can Be Opened Without The Key Fob Being In The Proximity Of The Vehicle
    02/16/11 … 2011 … #07-001-11 …. Coolant Weepage At The Coolant Reservoir Hose
    02/11/11 … 2011 … #18-008-11 …. Flash: Idle Boom Condition (3.6L) (supersedes 18-024-10)
    02/05/11 … 0910 … #18-005-11 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor (3.5L) Intermittent Set
    11/02/10 … 2010 … #08-028-10a .. RBZ Radio Software Enhancements
    10/30/10 … 0910 … #18-029-10 …. Flash: MIL Illumination P0138 And/Or P0158 (3.5L)
    10/21/10 … 0810 … #23-018-10 …. Lower Door Hinges Make Popping or Groan When Opened Or Closed
    08/13/10 … 2010 … #22-003-10 …. Slight Vibration at Highway Speeds (18" wheels)
    07/28/10 … 0910 … #19-005-10 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers (5.7L RWD)
    07/28/10 … 0910 … #08-020-10 …. Remote Start Intermittently Inoperative
    07/23/10 … 0910 … #18-024-10 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L)
    07/08/10 … 2009 … #18-015-10b .. Flash: MIL Illumination For P2181 - Cooling System Performance (3.5L)
    06/28/10 … 0810 … #08-014-10 …. REN and REZ Radio Lock Up. Flash Radio with DVD Update Disc
    05/14/10 … 2010 … #08-010-10 …. Flash: WIN Module For Intermittent RKE Functions
    04/30/10 … 0910 … #08-008-10 …. Flash: Amplifier for Speaker Distortion
    04/28/10 … 2009 … #18-014-10 …. Flash: Engine Runs Rough At Low RPM or MIL Illum. For MDS Reactivation and Misfire DTC's (5.7L)
    03/27/10 … 2010 … #18-008-10 …. Flash: MIL Illumination Or Failed/Rejected At State I/M Test Station Per Symptom/Conditions
    12/11/09 … 2009 … #18-021-09a .. Flash: MIL Illum And/Or MDS Driveability Improvements And/Or Shift Improvements (supersedes 18-021-09)
    11/05/09 … 2010 … #18-032-09 …. Flash: MIL Illumination P0133 And/Or P0153 (SRT8 6-speed)
    10/15/09 … 2009 … #18-030-09 …. Flash: Driveability Improvements (SRT8)
    09/15/09 … 0910 … #05-002-09b .. Pre Delivery - Front Brake Rotor Corrosion Inspection & Procedure (supersedes 05-002-09a)
    09/01/09 … 0809 … #14-001-09a .. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly (supersedes 14-001-09)
    08/13/09 … 2008 … #08-013-09 …. Flash: Incorrect Translation For "Oil Change Required" On EVIC Display In Spanish & French Language
    08/01/09 … 2009 … #19-004-09 …. Steering Wheel Returnability
    07/29/09 … 0809 … #22-002-09 …. Chrome Clad Wheel Adapters For Proper Balancing
    07/11/09 … 2009 … #18-021-09 …. Flash: MIL Illumination And/Or MDS Driveability Improvements And/Or Shift Improvements
    07/10/09 … 2009 … #19-003-09 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers
    07/09/09 … 2009 … #18-006-09a .. Flash: MIL Illumination For P0307 And/Or P0133 And/Or P0153 (supersedes 18-006-09)
    05/28/09 … 2009 … #21-005-09 …. Flash: Harsh 4-3 Shift And Shift Quality Improvements
    04/15/09 … 2009 … #14-001-09 …. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly
    03/31/09 … 2008 … #23-006-09 …. Decklid Spoiler Fit
    02/13/09 … 0809 … #08-003-09 …. MyGig REN or REZ Radio Inoperative After Battery Disconnect
    02/11/09 … 2009 … #18-006-09 …. Flash: MIL Illumination For P0307 - Cylinder 7 Misfire (SRT8)
    01/29/09 … 2009 … #18-002-09 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (SRT8)
    11/22/08 … 2009 … #18-040-08 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L)
    11/04/08 … 0809 … #05-005-08 …. Flash: ESP Lamp Flashing While System is in Full Off Mode Or ESP Pump Howl, Groan Sound After A Turn
    10/21/08 … 2009 … #08-031-08 …. Flash: Trip B Functionality Does Not Reset Using The Odometer Knob
    10/08/08 … 2009 … #21-022-08 …. Torque Convertor Shudder On Vehicles With Less Than 4000 Miles (4-speed only)
    09/18/08 … 2008 … #08-028-08 …. Voice Recognition Screen Lock-up on REN or REZ Radio Equipped With Uconnect
    09/17/08 … 2008 … #21-021-08 …. Automatic Transmission Diagnostic Tear Down Procedure
    08/29/08 … 2008 … #08-027-08 …. UConnect and Voice Recognition Inoperative
    08/20/08 … 2008 … #08-025-08 …. Keyless Go Feature Inoperative
    08/07/07 … 2008 … #23-035-07 …. Exterior Lamp - Lens Fogging
    03/08/06 … 0809 … #23-014-06 …. Windshield Wiper Blade/Element Maintenance
    Recalls
    RCL Date .. Model Yr .. Recall # ….......................... Description......................
    02/12/2014 … 0912 … RC-P01 …... Engine Timing Chain and Chain Guide
    05/00/2013 … 1112 … RC-N07 ..…. Seat Wiring Harness Connectors
    04/00/2013 … 2013 … RC-N18 ..…. Engine Starter Battery Positive Terminal
    08/00/2010 … 2011 … RC-K08 ..…. Wireless Ignition Node Receiver
    11/00/2009 … 0910 … RC-J27 ….... Front Wheel Hub Nuts
    02/00/2009 … 2009 … RC-H41 …... Tire Pressure Monitor Sensors
    09/00/2008 … 0809 … RC-H29 …... Reprogram Wireless Ignition Node (USA)
    09/00/2008 … 0809 … RC-CH29 …. Reprogram Wireless Ignition Node (Canada)
    RRT Date .. Model Yr … RRT # …............................ Description......................
    06/11/10 … 2010 … RRT-10037 …. Low Power Steering Fluid
    05/25/10 … 2010 … RRT-10030 …. RBZ Radio – Direct Tune Buttons Inoperative
    04/23/10 … 2010 … RRT-10024 …. Manual Transmission Pops Out Of Second Gear
    04/22/10 … 2010 … RRT-10023 …. Cruise Control Inoperative
    04/19/10 … 2010 … RRT-10022 …. Flash: WIN Module (Intermittent FOBIK Functions)
    03/25/10 … 2010 … RRT-10019 …. RBZ Radio - Video Disable
    02/26/10 … 2009 … RRT-10013 …. Sunroof Mechanism Cover Loose and or Cracked
    02/08/10 … 2009 … RRT-10006 …. Steering Wheel Returnability
    11/11/09 … 2010 … RRT-09085 …. Center Console Lid
    10/19/09 … 2009 … RRT-09047b .. Roof Molding Paint Cracking (supersedes 09-047)
    10/14/09 … 2009 … RRT-09073 …. Flash: Driveability Improvements (SRT8)
    09/28/09 … 2009 … RRT-09066 …. Grille Blister
    09/17/09 … 2009 … RRT-09060 …. Sun Visor Vanity Mirror Cover Looseness
    09/11/09 … 2009 … RRT-09059 …. 5/100 Powertrain Warranty (Owner Manual Kit Replacement)
    08/12/09 … 2009 … RRT-09047 …. Roof Molding Paint Cracking
    08/10/09 … 2009 … RRT-09046 …. Deck Lid Misalignment
    08/04/09 … 2009 … RRT-09043 …. Flash: PEM Module ("Key Not Detected" issue)
    06/03/09 … 0809 … RRT-09037 …. Passenger Side - Heated Seat Wire Retention
    05/01/09 … 2009 … RRT-09028 …. Door Glass Chip
    04/29/09 … 2009 … RRT-08098a .. Right Outside Rearview Mirror Loose (supersedes RRT-08-079)
    04/07/09 … 2009 … RRT-09019 …. No Start, Hard Start, Long Crank (See CSN-J21)
    03/30/09 … 2009 … RRT-09018 …. MYGIG Radio - Splash Screen Frozen or Locked Up With Battery Drain
    02/11/09 … 2009 … RRT-09009 …. Flash: MIL Illumination With DTC P0307 - Cylinder 7 Misfire Set
    01/23/09 … 2009 … RRT-09005 …. Right Camshaft Not Built To Proper Specification
    12/22/08 … 2009 … RRT-08098a .. Flash: Whistle Sound From Engine Compartment/Purge Solenoid
    11/10/08 … 2009 … RRT-08088 …. “DODGE” Lettering Loose On Rear Deck Appliqué
    10/09/08 … 2009 … RRT-08079 …. Right Outside Rearview Mirror Loose
    09/25/08 … 2009 … RRT-08077 …. Sirius Satellite Radio Inoperative
    08/22/08 … 2008 … RRT-08066 …. RKE FOBIK Loss Of Keyless Entry Function
    10/00/2012 … 2011 … CSN-M24 …. Smart Glass Switch
    03/00/2012 … 2012 … CSN-M04 …. Engine Oil Addendum Card and Tip Card (SRT)
    03/00/2012 … 2011 … CSN-L28 …. Front Exterior Door Handles
    05/00/2011 … 2011 … CSN-L19 …. Floor Mats
    04/00/2011 … 2011 … CSN-L10 …. Coolant Reservoir Outlet Hose
    04/00/2010 … 2010 … CSN-J36 …. Audio Control Switches
    11/00/2009 … 2009 … CSN-J21 …. Hot Start Engine Cranking (replaces RRT-09019)
    Miscellaneous issues
    TT Number .. Model Yr ….…................................... Description......................
    TT9002047 … 0809 … Door glass freezes to outer belt molding when vehicle subjected to rain then freezing temperatures (Application of (AQUAPEL) glass treatment to the outer door glass surface)
    TT9001995 … 2009 … Taillamp letters falling off (Letters available individually, D= P/N 68060396AA, O= 68060397AA, G= 68060398AA, E =68060401AA
    TT9001970 … 0809 … Seat cushion to seat back frame bolts too long (New shorter replacement bolt available, p/n 68039245AA)
    TT9001942 … 0809 … Rear fascia wavy/warped (Fascia is not defective, black surround trim piece is the root cause)
    TT9001825 … 0809 … Rear speakers inoperative, balance not working (Select stereo mode in EVIC and recheck sound from rear speakers)
    TT9001932 … 0809 … Ticking or buzz noise in engine compartment when cooling fan running, vehicles built before 7/31/08 (Check the upper radiator seal, move up & back into position if necesssary)
    TT9001897 … 0809 … Fuel fill door rubber bumpers (Rubber bumpers are serviced separately by ordering P/N 68054811AA)
    TT9001868 … 0809 … A-pillar gauge pod, Mopar p/n 77060062, interference with side air bags (NOT compatible with 2008-2009 Challengers)
    TT9000723 … 0809 … Decklid - hard to close or binding condition (Adjust striker if binding; chk emergency trunk handle to verify cross-car play to insure decklid will latch)
    K55325103 … 2009 … Unable to shift vehicle out of park (body wiring harness in drivers kick panel may contact parking brake assembly, chk wiring)
