TSBs and Recall Information
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by SRT-Tom, Feb 7, 2012.
    Part 1. TSB's (Technical Service Bulletins)
    TSB Date .. Model Yr … TSB # …............................ Description......................
    08/13/10 … 2010 … #22-003-10 …. Slight Vibration at Highway Speeds (18" wheels)
    07/28/10 … 0910 … #19-005-10 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers (5.7L RWD)
    07/28/10 … 0910 … #08-020-10 …. Remote Start Intermittently Inoperative
    07/23/10 … 0910 … #18-024-10 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L)
    07/08/10 … 2009 … #18-015-10b .. Flash: MIL Illumination For P2181 - Cooling System Performance (3.5L)
    06/28/10 … 0810 … #08-014-10 …. REN and REZ Radio Lock Up. Flash Radio with DVD Update Disc
    05/14/10 … 2010 … #08-010-10 …. Flash: WIN Module For Intermittent RKE Functions
    04/30/10 … 0910 … #08-008-10 …. Flash: Amplifier for Speaker Distortion
    04/28/10 … 2009 … #18-014-10 …. Flash: Engine Runs Rough At Low RPM or MIL Illum. For MDS Reactivation and Misfire DTC's (5.7L)
    03/27/10 … 2010 … #18-008-10 …. Flash: MIL Illumination Or Failed/Rejected At State I/M Test Station Per Symptom/Conditions
    12/08/09 … 2009 … #18-021-09a .. Flash: MIL Illum And/Or MDS Driveability Improvements And/Or Shift Improvements (supersedes 18-021-09)
    11/05/09 … 2010 … #18-032-09 …. Flash: MIL Illumination P0133 And/Or P0153 (SRT8 6-speed)
    10/15/09 … 2009 … #18-030-09 …. Flash: Driveability Improvements (SRT8)
    09/15/09 … 0910 … #05-002-09b .. Front Brake Rotor Corrosion Inspection & Procedure (supersedes 05-002-09a)
    09/01/09 … 0809 … #14-001-09a .. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly
    08/13/09 … 2008 … #08-013-09 …. Flash: Incorrect Translation For "Oil Change Required" On EVIC Display In Spanish & French Language
    08/01/09 … 2009 … #19-004-09 …. Steering Wheel Returnability
    07/29/09 … 0809 … #22-002-09 …. Chrome Clad Wheel Adapters For Proper Balancing
    07/11/09 … 2009 … #18-021-09 …. Flash: MIL Illumination And/Or MDS Driveability Improvements And/Or Shift Improvements
    07/10/09 … 2009 … #19-003-09 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers
    07/09/09 … 2009 … #18-006-09a .. Flash: MIL Illumination For P0307 And/Or P0133 And/Or P0153 (supersedes 18-006-09)
    05/28/09 … 2009 … #21-005-09 …. Flash: Harsh 4-3 Shift And Shift Quality Improvements
    04/15/09 … 2009 … #14-001-09 …. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly
    03/31/09 … 2008 … #23-006-09 …. Decklid Spoiler Fit
    02/13/09 … 0809 … #08-003-09 …. MyGig REN or REZ Radio Inoperative After Battery Disconnect
    02/11/09 … 2009 … #18-006-09 …. Flash: MIL Illumination For P0307 - Cylinder 7 Misfire (SRT8)
    01/29/09 … 2009 … #18-002-09 …. MIL Illumination Diagnostic Trouble Code P0339 - Crankshaft Position Sensor Intermittent (SRT8)
    11/22/08 … 2009 .. #18-040-08 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L)
    11/04/08 … 0809 … #05-005-08 …. Flash: ESP Lamp Flashing While System is in Full Off Mode Or ESP Pump Howl, Groan Sound After A Turn
    10/21/08 … 2009 … #08-031-08 …. Flash: Trip B Functionality Does Not Reset Using The Odometer Knob
    10/08/08 … 2009 … #21-022-08 …. Torque Convertor Shudder On Vehicles With Less Than 4000 Miles (4-speed only)
    09/18/08 … 2008 … #08-028-08 …. Voice Recognition Screen Lock-up on REN or REZ Radio Equipped With Uconnect
    09/17/08 … 2008 … #21-021-08 …. Automatic Transmission Diagnostic Tear Down Procedure
    08/29/08 … 2008 … #08-027-08 …. UConnect and Voice Recognition Inoperative
    08/20/08 … 2008 … #08-025-08 …. Keyless Go Feature Inoperative
    08/07/07 … 2008 … #23-035-07 ... Exterior Lamp - Lens Fogging
    03/08/06 … 0809 … #23-024-06 ... Windshield Wiper Blade/Element Maintenance
    Part 2. RECALLS
    RCL Date .. Model Yr .. Recall # ….......................... Description......................
    11/00/2009 … 2009 … RC-J21 …. Hot Start Engine Cranking
    11/00/2009 … 0910 … RC-J27 ….... Front Wheel Hub Nuts
    02/00/2009 … 2009 … RC-H41 …... Tire Pressure Monitor Sensors
    09/00/2008 … 0809 … RC-H29 …... Reprogram Wireless Ignition Node (USA)
    09/00/2008 … 0809 … RC-CH29 …. Reprogram Wireless Ignition Node (Canada)
    Part 3. Rapid Response Transmittals
    RRT Date .. Model Yr … RRT # …............................ Description........
    06/11/10 … 2010 … RRT-10037 …. Low Power Steering Fluid
    05/25/10 … 2010 … RRT-10030 …. RBZ Radio – Direct Tune Buttons Inoperative
    04/23/10... 2010 … RRT-10024 …. Manual Transmission Pops Out Of Second Gear
    04/22/10 … 2009 … RR-10023 ....… Cruise Control Inoperative
    04/19/10... 2010 … RRT-10022 …. Flash: WIN Module (Intermittent FOBIK Functions)
    02/26/10 … 2009 … RRT-10013 …. Sunroof Mechanism Cover Loose or Cracked
    02/08/10 … 2009 … RRT-10006 … Steering Wheel Returnability
    11/11/09 … 2010 … RRT-09085 …. Center Console Lid
    10/19/09 … 2009 … RRT-09047b .. Roof Molding Paint Cracking (supersedes 09-047)
    10/14/09 … 2009 … RRT-09073 …. Flash: Driveability Improvements (SRT8)
    09/28/09 … 2009 … RRT-09066 …. Grille Blister
    09/17/09 ...2009... RRT-09060 …. Sun Visor Vanity Mirror Cover Loose
    09/11/09 … 2009 … RRT-09059 …. 5/100 Powertrain Warranty ...manual replacement
    08/12/09 … 2009 … RRT-09047 …. Roof Molding Paint Cracking
    08/10/09 … 2009 … RRT-09046 …. Deck Lid Misalignment
    08/04/09 … 2009 … RRT-09043 …. Flash: PEM Module ("Key Not Detected" issue)
    06/03/09 … 0809 … RRT-09037 …. Passenger Side - Heated Seat Wire Retention
    05/01/09 … 2009 … RRT-09028 …. Door Glass Chip
    04/29/09 … 2009 … RRT-08098a .. Right Outside Rearview Mirror Loose (supersedes RRT-08-079)
    04/07/09 … 2009 … RRT-09019 …. No Start, Hard Start, Long Crank
    03/30/09 … 2009 … RRT-09018 .. MYGIG Radio - Splash Screen Frozen or Locked Up With Battery Drain
    02/11/09 … 2009 … RRT-09009 …. Flash: MIL Illumination With DTC P0307 - Cylinder 7 Misfire Set
    01/23/09 … 2009 … RRT-09005 …. Right Camshaft Not Built To Proper Specification
    12/22/08 … 2009 … RRT-08098a .. Flash: Whistle Sound From Engine Compartment/Purge Solenoid
    11/10/08 … 2009 … RRT-08088 …. “DODGE” Lettering Loose On Rear Deck Appliqué
    10/09/08 … 2009 … RRT-08079 …. Right Outside Rearview Mirror Loose
    09/25/08 … 2009 … RRT-08077 …. Sirius Satellite Radio Inoperative
    08/22/08 … 2008 … RRT-08066 …. RKE FOBIK Loss Of Keyless Entry Function
    Part 4. Miscellaneous issues
    TT Number .. Model Yr ….…................................... Description......................
    TT9002047 … 0809 … Door glass freezes to outer belt molding when vehicle subjected to rain then freezing temperatures (Application of (AQUAPEL) glass treatment to the outer door glass surface)
    TT9001995 … 2009 … Taillamp letters falling off (Letters available individually, D= P/N 68060396AA, O= 68060397AA, G= 68060398AA, E =68060401AA
    TT9001970 … 0809 … Seat cushion to seat back frame bolts too long (New shorter replacement bolt available, p/n 68039245AA)
    TT9001942 … 0809 … Rear fascia wavy/warped (Fascia is not defective, black surround trim piece is the root cause)
    TT9001825 … 0809 … Rear speakers inoperative, balance not working (Select stereo mode in EVIC and recheck sound from rear speakers)
    TT9001932 … 0809 … Ticking or buzz noise in engine compartment when cooling fan running, vehicles built before 7/31/08 (Check the upper radiator seal, move up & back into position if necesssary)
    TT9001897 … 0809 … Fuel fill door rubber bumpers (Rubber bumpers are serviced separately by ordering P/N 68054811AA)
    TT9001868 … 0809 … A-pillar gauge pod, Mopar p/n 77060062, interference with side air bags (NOT compatible with 2008-2009 Challengers)
    TT9000723 … 0809 … Decklid - hard to close or binding condition (Adjust striker if binding; chk emergency trunk handle to verify cross-car play to insure decklid will latch)
    K55325103 … 2009 … Unable to shift vehicle out of park (body wiring harness in drivers kick panel may contact parking brake assembly, check wiring)
    PART 5.... CUSTOMER SATISFACTION NOTICES
    04/00/2010 … 2010 … CSN-J36 …. Audio Control Switches
