Upgrade speakers
Discussion in 'Challenger Audio/Video/Electronics Modifications' started by Joerocket, May 7, 2012.
  1. Joerocket
    Joerocket New Member
    New York
    Hi,
    I have a 2012 R/T. I haven't removed any panels yet. How are the speaker wires? Are they thin wires on the harness or are they useable with an amp? Thanks
  2. mthomas92
    mthomas92 Member
    Norwood MA
    the only wiring you should worry about, as in any vehicle is the harness behind the unit.. witch in the mopar world the color code is crazyy... but only if ur changeing just the speakers you need to be in the door panels and stuff, and thats just to cut and re solder connections.
  3. 2009SE
    2009SE Active Member
    NW Arkansas
    They are thin.
    Thin as cheap spaghetti...
    Cutting and splicing is not recommended.
    Run quality wire.
    Thin stuff adds ohms to the circuit and steals power from the speakers.
    Speaker dampening also suffers.
    Do it right or dont do it. :)
