Hello all, I am new here. 2019 Challenger T/A 392, 6 spd. Created an account to find out what is going on with the car. I have a brand new water drip that appeared under the passenger dash behind the glove box. The drip is intense after driving around with AC on full blast and re-circulation. I heard some clattering sound at times and then the drip. I did a quick search for "AC compressor" "AC condenser" and "AC drain line" without any solid results. As far as I am aware the heater core and items are the only things back in there, but no clue why that would leak. The compressor is in the engine bay and is dry. The condenser is by the radiator and is dry. Would the AC drain line by the transmission being plugged under the car cause this leak? If someone would help me, I would greatly appreciate it.
Try and blow compressed air into the rubber nipple. Would work best when the AC has run a while, and built up water.
