Anybody want to trade for my 20" OEM Wheels/Tires?
Discussion in 'Dodge Challenger General Discussions' started by tklietz, Jun 3, 2021.
  1. mikeT
    mikeT Full Access Member
    AZ
    If it's black not too noticeable Any other color, paint the wheel well black
  2. tklietz
    tklietz Member
    Montana
    Thanks all! Yep - plan is to go with the 255 18s. One thing I still haven't figured out yet though is that in using 18" tires, I'm supposed to drop the tire pressure to about 26 pounds - don't know how that will work with the tpms - ie if the dummy light will stay on at the lower pressure.
    Well I know at 15 lbs the TPMS Sensor flashes :)
    :driver::driver:
    NC20RT and tklietz like this.
  4. 68MOPAR
    68MOPAR Full Access Member
    Terra
    I want 17" wheels.
    If 15x7" front & 15x12" rear would just fit over my Brembo's. . . .
  6. 68MOPAR
    Terra
    Wilwood calipers?
  7. tklietz
    tklietz Member
    Montana
    Hi all - still wanting smaller wheels. I did end up installing wheel spacers - would that mean that I could go smaller than 18" with the OEM brakes?
  8. B5blueRT
    You'll need someone with 18" wheels to reply to you. I still have my 20" wheels one. Ride quality is subjective but the ride I get when the 18" wheels are on is noticeably softer and I run them at 32 PSI. Since 18's are the standard wheels for the Challenger, not sure I'd go smaller than that unless someone tells you there's a bunch of clearance for the brakes calipers.
    tklietz likes this.
