Engine tick
Discussion in 'Dodge Challenger General Discussions' started by Josh82, Oct 14, 2019.
  1. 2017 Redline HC
    Isn’t the bad camshaft issue related to faulty lifters wearing the cams out? I have read the rollers seize and wear out the cam lobe.
  2. STEVEN NIX
    STEVEN NIX Active Member
    long island new york
    Yes, that is exactly what is happening. it also happens on 6.4l with MDS. a slight ticking is normal for all the 5.7L and 6.4L engines. that is why they have so many covers to dampen noises. you will hear some from the injectors, and roller lifters tend to be noisey. if you have a ticking noise that is exceptionally loud, you have a problem. if it's a little noisey, it's loose and happy.
  3. STEVEN NIX
    I have had situations when you drove normally the car would run smooth, as soon as you punched it and came back down to an idle it would start misfiring. we usually get them when the CEL is already on and the engine is misfiring. most people aren't as in tune with their cars as the people i meet on the forums.
  4. baccaruda
    baccaruda Full Access Member
    Same here..... Ow-40 Mobil one against the rules.,,....
  5. 2017 Redline HC
    So why isn’t Chrysler doing a recall to replace the lifters?
  6. STEVEN NIX
    Not that common a problem and if they decide to do anything about it they will probably just extend the warranty on them, like the left side 3.6L cylinder heads.
    IntimidatorRT likes this.
  7. JJK
    JJK Member
    It's funny that you guys are saying this stuff. When I was looking for a '15, I actually walked away for from one brand new on the lot because of ticking. The salesman just stood there and shook his head. I did buy another '15 and it does tick when first starting for a bit. Changed oil to Valvoline synthetic and still have just a little tick now. Just turned 8700 mile. Pretty sure it's just a Hemi 5.7 thing.
  8. HemiFeverAZ
    San Tan Valley Arizona
    I run 1 quart Lucas stabilizer with my Lucas 0-40w
