Pedal Kit
Discussion in 'Challenger Interior Modifications' started by Storm Rider, Sep 24, 2011.
  1. genotex
    genotex Full Access Member
    WIzzzzzconsin
    Anybody ELSE with a 6spd pick up one of those MBenz emergency brake pedals? I like mine... fit like a charm :)
  2. jonmandude
    jonmandude Full Access Member
    the dreaded rust belt
    I did. It went on very easy
  3. Bullishman13
    NC
    I had to relief cut mine to fit. Mine is the 2008 SRT8 auto transmission.
    Used 3M double sided tape to hold it on. I'll have to redo it here soon. Keeps popping off.
    Did you guys know that you can buy the parking brake pedal cover from these two sources?
    ULTIMATE PEDALS
    (You want the Charger pedal with the shiny finish and domed insert- $25. They look great. Here are mine).
    You can also buy it from Mercedes parts.
    Tip: No need to drill the pedals. You can easily attach the covers by using Velcro.
    If you want to mount them permanently, use JB Weld (epoxy cement).
  6. walnetto
    walnetto Full Access Member
    Wisconsin
    Is there a difference from the automatic or manual transmission cars? I know the releasing mechanism is different.
  7. SRT-Tom
    The emergency brake cover from Ultimate Pedals will work on the auto or manual. Like I said, just use Velcro to secure it. Mine has been on for 2 1/2 years with no problems.
  8. Bullishman13
    NC
    :favorites37:Mine is now secured via Gorilla glue.
  9. genotex
    WIzzzzzconsin
    I believe there's a difference in size of the pedals... let's check next time we're together Tom :) You bring the measuring tape!
  10. SRT-Tom
    There may be a difference, but the emergency brake cover is big enough to cover both the auto and manual pedals.
