Personalized plates. Mine finally arrived after 7 weeks.
Discussion in 'Dodge Challenger General Discussions' started by NC20RT, Jan 21, 2021.
  1. Yarddog
    Yarddog Member
    Canton, Ohio
    Agreed about the logo. It will come off when the weather warms up. Need to order license bracket also. Any ideas for that would be greatly appreciated.
    Sent from my SM-G960U using Tapatalk
  2. B5blueRT
    Check out WeatherTech if you just want a frame w/o lettering. They have a nice one with a clear plexi cover and weather seal so water doesn't get trapped in between the plate and the inside of the clear cover.
  3. NC20RT
    I just have the simple black frame to outline my plate. Many choices on ebay to get whatever you prefer. The black just happens to match well with the black and orange on my car.
    Yarddog likes this.
  4. Yarddog
    Yarddog Member
    Canton, Ohio
    Got the logo of today and frame ordered.
  5. Gregory Cooper
    Idaho
    What are your states laws on front license plates?????
    Here in Idaho the law is a front plate is mandatory. There is a $65.00 fine if your pulled over and cited for not having a front plate.
    Mostly only state troopers enforce that law.
    My R/T came without a front plate mount. I will not put screws into the front bumper, so, if I get a fine I will pay it (again).
  6. IntimidatorRT
    Your lucky the dealer didn’t mount a factory license plate bracket on it., most of the time you will find it in the trunk. I used 7” toggle bolts for mine, mounted it through the lower grille. No holes drilled.
  7. Bacon Sandwich
    Middle Georgia
    They make a stow-away plate holder that swings up for use, I've seen them at shows where plates are mandatory
  8. TRCM
    TRCM Full Access Member
    Southeast VA
    Those also cost you ground clearance, which most of us have precious little of to begin with......
  9. Wizard of Iz
    Thank God, Florida doesn't use front license plates.
    If we had to use one, I'd get a Sto-n-Sho before I'd drill holes in the font bumper. When I'm searching for vehicles, I won't even consider a car that has a front plate holder. It's a HARD stop for me.
  10. NC20RT
    ^^^ No front plate in NC either. I've been lucky living in both FL & NC with no front plates. small (2).JPG
