Oil Drain Plug Torque - 2015 5.7L Hemi
Discussion in 'Challenger R/T Engine & Performance Modifications' started by Eagle1450, Nov 11, 2014.
  1. Eagle1450
    Eagle1450 Full Access Member
    I am sure that this information is on the site somewhere but I cannot find it. If anyone has a 2015 shop manual could you provide me with the correct torque for the oil drain plug. I am guessing between 20-25 Ft Lbs but want to be exactly correct. Thanks in advance.
    The correct torque for the oil drain plug is 25 ft/lbs.
  3. Eagle1450
    Thank you very much SRT-Tom. I suspected that was the correct torque but it pays to be sure. I plan to buy a shop manual for my 2015 in the near future so I won't have to ask any more rudimentary questions. Thanks again!
  4. jim
    jim Full Access Member
    Palm Coast, fl.
    Is there a washer that has to be replaced on the oil drain plug when changing oil.
    Thanks, Jim
  5. Eagle1450
    No. The rubber seal in the drain plug does not have to be replaced and should last a very long time. I did 40+ oil changes on my 2001 Ram before I traded it. The seal on the drain plug (same design as on the current Challengers) was still good after all that time.
  6. jim
    Palm Coast, fl.
    Thanks
