Oil Change
Discussion in 'Challenger DIY/Tech Info' started by SRT-Tom, Dec 27, 2013.
    Oil Change Tip
    Anyone using a "fast-flow" stepped-up tube funnel and 5 qt. wide-mouth oil jugs, be careful.
    If you fast fill a 5.7 too fast, an air bubble will occur and the oil will back up and flow through the PCV intake hose, below the oil fill port, and onto your driveway creating a big mess!
    Just take your time and remember to fill the filter before you start the engine.
  2. JJK
    JJK Member
    OIl velocity
    What grade of oil do you use. 5w20 sounds awful light. I was thinking 5w30 with 16oz of marvel oil myself.
  3. Wizard of Iz
    Stick with 5W-20 for the 5.7 Hemi. It's just right.
  4. UKCrafty
    UKCrafty Member
    5w20 is what the 5.7 calls for if you are going to change the grade I would go with a 0w20 and not a 5w30, also I use Mobil 1 Extended Performance 5w20 and still change it every 3000, if I go over I have no need to worry!
    Sent from my SM-N910T using Tapatalk
  5. nixkuiper
    nixkuiper New Member
    What oil should I use for the 6.4L Scat Pack?
  6. nixkuiper
    Feel like paying $110 for an oil change at the dealership is a bit excessive
    Use 0-40W synthetic. Pennzoil and Mobil 1 are two excellent brands.
    Good prices are available at Wal Mart.
  8. SRT-Tom
    Do not use 0-20W oil in your 5.7 Hemi.
    The 5.7 Hemi uses a Multiple Displacement System (MDS). If you use the lighter weight, improper operation of the MDS and other engine problems may occur.
  9. nixkuiper
    Thank you! Very informative!
  10. UKCrafty
    UKCrafty Member
    I work with oil all day long and 0w20 would not affect the MDS as it is a 20 weight oil after start up the 5 & 0 is the start up weight!!
