2012 6 speed 440
Discussion in 'Prospective Challenger Owners Forum' started by floridabob, Feb 16, 2017.
  1. floridabob
    floridabob New Member
    Trying to decide if I should buy a 2012 Challenger with the following details:
    52k miles
    6 speed
    cloth w/leather trim
    sunroof
    upgraded radio
    hood scoop hood w/AEM air cleaner
    Arrington Performance NA 440 balanced and blue printed w/527 dynoed hp
    Heavy Duty Clutch
    Diablosport Tuner
    Four Point Strut Tower braces front and rear
    Subframe connectors
    Heavy duty rear axle locators
    2 quart oil cooler (9qts total)
    custom wheels
    custom exhaust
    I'm sure I'm forgetting some things but is it worth buying?
    Around $30k
    Southern car, one owner.
    Bob
  2. Climber
    Climber Full Access Member
    Castle Rock, Co.
    I am confused. A 2012 with a 440? Is that correct? I guess that such an engine swap could be done. The last good year for a factory 440 was '71. If this 2012 does in fact have a 440 I would like to know how it performs hooked up to a modern 6 speed manual.
  3. redbullssg
    redbullssg Active Member
  4. redbullssg
    Arrington 440.... It's aftermarket, not stock....
    Sent from my LG-V410 using Tapatalk
  5. 14RT
    14RT Member
    You're joking...right? Arrington 440 is a stroked and bored modern hemi block...not the old school heavy iron big block 440
  6. 14RT
    14RT Member
    Sounds like a badass car man, buy it!
