SRT8 Alcoa Wheels on 2016 R/T
Discussion in 'Challenger Wheels, Tires and Brakes Forum' started by AngryLemur, Dec 2, 2018.
  1. reerc
    reerc New Member
    Spanish Fork
    The SRT Alcoa wheels are forged and have lighter unsprung weight than cast wheels.
    I, however, only recommend a 275/40-20 tire, as the maximum width, on this 9 inch wide wheel. Sure, you can squeeze a 285 or 295 tire on it, but the tire will not wear or perform properly (see diagram #2). Also, it may be dangerous.
  3. AngryLemur
    AngryLemur Member
    20190214_205931.jpg Resurrecting a dead post that I started....I did find some OEM ALCOA SRT wheels and put 275/40/R20s on them. They needed the 5mm spacers to fit on a 2016 R/T. So far, they are great!
    Looking good!
    I have two sets of then :)
  5. IntimidatorRT
    why did you need the spacers?. I have seen them on other RT with out the spacers.
    I thought that the Alcoa forged wheels that came stock on the SRT, require 3mm spacers on the R/T to prevent rubbing.
  7. AngryLemur
    AngryLemur Member
    The installer tried them without the spacers but the front wheels rubbed.
    I'd heard different answers from no spacers to 3mm to 5mm were needed, so I just ordered the 5mm just in case. I may get 3mm to see if they will work.
  8. IntimidatorRT
    where does it rub?
  9. AngryLemur
    AngryLemur Member
    I thought he said the rubbing was on the upper control arms on the front tires
  10. SRT-Tom
    That's correct, the rubbing is especially noticeable when turning.
