275/40- 20 Tires
Discussion in 'Challenger Wheels, Tires and Brakes Forum' started by SRT-Tom, Jan 26, 2018.
    It's surprising that you have had no apparent problems with the 295/40-20 size. According to all tire guides, the widest tire that you can safely put on a 9 inch wheel is a 275/40-20. Otherwise it will be "pinched" and may not wear or perform properly. See the following diagram (middle image). [/QUOTE]
    Nope, tires sit flat on the ground, just a slight bulge,
    Less than I had with L60-15’s back in the day
    Your tire fitment attachment supports my statement. A 295/40-20 tire needs a minimum 10-inch wide wheel. Better would be an 11-inch wide wheel. A 9-inch wide wheel is too narrow. Although your tire's tread looks flat, the bead of your tire is definitely pinched.
    No problems so far and I put more miles on this thing than most of you :)
    But that is why I am looking for 285/40ZR20's when I buy NEW rear tires.
    It does looks really stupid to put 245/45/20's on 9" from the factory when it calls for 7 1/2"-9" for those tires.
    I agree. With all of the torque that these Hemi engines produce, a wider tire is necessary. Besides, they give the Challenger a cooler muscle car look.
    Moparisto likes this.
  6. HemiFeverAZ
    San Tan Valley Arizona
    The bfg GeForce 2 as worked flawless on a 4 corners was a good fit with 20x9 no issues with lowered kit
  7. HemiFeverAZ
    My next set will be staggered getting the Continentals Extreme Contact Sport rubber
    275 40 20 rear with 245 45 40 fronts
  8. SRT-Tom
    That is the "old school" set up that I have on my 2009 SRT. If you want to save some bucks, you might want to consider the new Cooper Zeon RS3-G1 tire. It got excellent reviews. I installed them on my Challenger and they perform great. As a bonus, they have a 500 AAA rating.
    Sidewinderbob and HemiFeverAZ like this.
  9. Sidewinderbob
    Sidewinderbob New Member
    Remsen, NY
    How did the coopers work out for you? And you do all 4?
  10. SRT-Tom
    I installed 245/45-20 Cooper tires on the front and 275/40-20 tires on the rear, for that "old school" staggered look.
    As expected, they perform great, look great and have no tread noise. With a 500AAA wear rating, I hope to have them for a long time. I highly recommend them.
    One word of concern. Supposedly, these all season tires do not perform well in moderate to deep snow. That, however, is not an issue for me since I never drive my SRT in bad weather.
    Sidewinderbob likes this.
