tranny fluid change...
Discussion in 'Dodge Challenger General Discussions' started by LEGENDARY70, May 1, 2020.
  1. LEGENDARY70
    TEXAS!
    Hello all.
    I bought my wife a 2010 SRT8 about a year ago. It had 69K on it. It is at 78K now. Not sure if it has ever had a tranny fluid flush. Should we do it?
    I have read where some say yes and some say no.
    what do the experts here think?
    thx
  2. tidefan1967
    tidefan1967 New Member
    South Carolina
    Flush or pan drop? Personally I wouldn't bother with a flush and go for the pan drop where you can replace the filter.
  3. 2017 Redline HC
    I agree with draining and dropping the pan so you can changeout the filter and clean any deposits sitting in the pan.
  4. Katshot
    Both actually have their pluses and minuses. Either way, I'd always change the filter if applicable. If the fluid appears in any way dark or dirty, I'd also flush the trans. The reason for this is that flushing replaces a far greater amount of the old fluid and truly is the only way to get foreign material out of the converter, valve body etc.
  5. IntimidatorRT
    yep, a filter change, when I did that I switched to using Amziol synthetic
  6. 70-426_10-SRT
    YES
    Even us M6 guys need to do it every 25k
  7. Katshot
    Really? Is that in the manual or something you just like to do?
  8. 70-426_10-SRT
    Well MOPAR went to ATF in the 6-speed, and yes, it requires changing every 25k
    I didn't think anything about it except my 1st trip to the track as right about that time
    (documented on this site somewhere)
    and about the 3rd pass I started having problems 2nd-3rd.
    Drained and replaced the fluid and took it out the next month, and shifting was smoother, but still fought Wheel Hop.
    With the Diff Stiffener SRT-Tom posted, I hope to shave off 1/2 sec or better.
    (If they open the track this year)
    LEGENDARY70 likes this.
  9. LEGENDARY70
    TEXAS!
    K. So either a pan drop and new filter? Or a full flush and new filter?
    Or should i wait until 100.000 miles?
    thx
  10. STEVEN NIX
    STEVEN NIX Active Member
    long island new york
    Perform Maintenance Every Maintenance Items
    (Where time and mileage are listed, follow the interval that occurs first.)
    Miles
    Kilometers Months
    6000 10000 6
    • Change the engine oil and engine oil filter.
    • Rotate tires.
    12000 20000 12
    • Rotate tires.
    • If you are using your vehicle in dusty or off-road conditions, inspect the engine air cleaner filter, and replace if necessary.
    • Replace the air conditioning filter.
    • Inspect the brake linings, and replace if necessary.
    • Inspect the CV joints. Perform the first inspection at 12,000 miles (20 000 km) or 12 months.
    • Inspect the exhaust system. Perform the first inspection at 12,000 miles (20 000 km) or 12 months.
    • Inspect the manual transmission fluid (if equipped), add as necessary.
    • Inspect the front suspension, tie rod ends and boot seals for cracks or leaks and all parts for damage, wear, improper looseness or end play; replace if necessary.
    18000 30000 18
    • Rotate tires.
    • Inspect the rear axle fluid.
    24000 40000 24
    • Rotate tires.
    • Change the manual transmission fluid (if equipped) if using your vehicle for any of the following: Most of your driving is at sustained high speeds during hot weather, above 90°F (32°C), driving in dusty conditions, or stop and go driving.
    30000 50000 30
    • Rotate tires.
    • Replace the engine air cleaner filter.
    • Adjust parking brake on vehicles equipped with four-wheel disc brakes.
    36000 60000 36
    • Rotate tires.
    42000 70000 42
    • Rotate tires.
    48000 80000 48
    • Rotate tires.
    • Change the rear axle fluid if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
    54000 90000 54
    • Rotate tires.
    60000 100000 60
    • Rotate tires.
    • Change the automatic transmission fluid and filter if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
    • Flush and replace the engine coolant at 60 months if not done at 102,000 miles (170 000 km).
    66000 110000 66
    • Rotate tires.
    72000 120000 72
    • Rotate tires.
    78000 130000 78
    • Rotate tires.
    84000 140000 84
    • Rotate tires.
    90000 150000 90
    • Rotate tires.
    • Inspect and replace the PCV Valve if necessary.*
    96000 160000 96
    • Rotate tires.
    • Change the manual transmission fluid (if equipped).
    102000 170000 102
    • Rotate tires.
    • Replace the spark plugs.
    • Flush and replace the engine coolant if not done at 60 months.
    108000 180000 108
    • Rotate tires.
    114000 190000 114
    • Rotate tires.
    120000 200000 120
    • Rotate tires.
    • Change the automatic transmission fluid and filter.
    126000 210000 126
    • Rotate tires.
    132000 220000 132
    • Rotate tires.
    138000 230000 138
    • Rotate tires.
    144000 240000 144
    • Rotate tires.
    150000 250000 150
    • Rotate tires.
    * This maintenance is recommended by the manufacturer to the owner, but is not required to maintain emissions warranty.
