Getting your Challenger alignment correct
Discussion in 'Challenger R/T Engine & Performance Modifications' started by IntimidatorRT, Jul 31, 2020.
  1. IntimidatorRT
    As you all know our cars are not lineable. No adjustments can be made on the front. Even if you lower it, it will be out of specs somewhat. I lowered mine with an SRT shock and spring setup about 6 years ago. The front was at its max as far as alignment goes. Last week I had adjustable upper control arms installed and today it is getting alignment to make everything back to normal specs. [​IMG]
    Purrrr66 likes this.
