Lots of mods you can do to the V6. Had mine for 2 years and put over $8000 in mods into it. Got over $10,000 in mods getting done in the next 6 months, including a supercharger and a stereo system upgrade. Nothing wrong with owning a V6.
Preach it brother! It's unfortunate to see guys with higher up models talking down upon owners of lower models. At the end of the day sure your car may cost more and have 100+ more hp than mine but in essence we're all driving the same car. Living in the same culture.
My apologies didn't see this, yes they have the red stripe built into the rim which was dinged up from the previous owner (didn't know how to park). I was able to strip them, deep clean, sand and repaint/refinish them.
Wheels turned out great. If you refinished them yourself, what paint color/manufacturer did you use and how did you apply the red stripe? I'll probably be refinishing my winter wheels next spring.
I removed the wheel so I had more access to them and deep cleaned them first. Used a bevel drill to smooth out and even the big chunks and then a sanding attachment to strip away the paint that was older. Cleaned them again and then used the "Dupli-Color Scratch Fix All-in-1" applicator. The color code which matches almost identically for the wheels is "Chrysler PR4 Poppy Red/Flame Red ACC 0419". Depending on the damage it took between 3-4 coats to get the desired color. Hope this helps.
are your wheels the ones that are skins and were you able to remove them to refinish,they look great I've got the same ones and hope to refinish over the winter
