Torque for Stabilizer bar bolts
Discussion in 'Dodge Challenger General Discussions' started by Janning, Nov 22, 2020.
  1. Janning
    Janning Full Access Member
  2. 2017 Redline HC
    I’ll check my manual later for you.
  3. Janning
    please do!! it is MUCH appreciated! I'm guessing only 2 at most different specs,,,,one for the 2 bar bushings and another for the 4 link bolts.
  4. IntimidatorRT
    hell, i would just hunker down on those things till tight....lol
  5. Katshot
    Me too. About the only things I actually torque are most engine hardware, differential hardware and sometimes wheels.
  6. Janning
    HA! that was my first instinct...but, I want to at least try to roque it to spec
  7. 2017 Redline HC
    Have a look at this, its from my 2017 manual. C6CA4031-4E4B-4750-836C-CDA9ACCAB4CE.jpeg
  8. Janning
    So way I read it....110 -111 on the left right stabalizer bar links........but, which one is the 2 bushings on the stabalizer bar itself? is that the 136?
  9. 2017 Redline HC
    Isn’t the stabilizer to crossmember the actual bushing volts?
  10. Janning
    HEll I don;t know....I know those left / rite Stabilzer bar links hook to what I call a sway bar....#1 in the pic in original post, that "stabilizer bar" has two bushings in a clamp, in th middle-ish of the bar about 12" apart. That sounds like the Tension strut to cradle ?
