Dash cam power feed......
Discussion in 'Challenger Audio/Video/Electronics Modifications' started by TRCM, Dec 31, 2020.
  1. TRCM
    TRCM Full Access Member
    Southeast VA
    Where'd you get that one ? All I can find around here so far is limited to a 10A fuse, and I need at least a 15A rating.....the wire on the ones I've seen is 1/2 if what you have there
  2. B5blueRT
    When in doubt search Rock Auto.... do a search for "fuse" then select "Fuse Holder" from the drop down menu.
  3. TRCM
    Southeast VA
    May end up going that route....was trying to find something local so I can have it in hand now.....
    What you show are fuse holders...not fuse taps....I want something like FrankenMax showed....I have fuse holders.....
    I do not want to cut into any factory wiring.....
  4. FrankenMax
    FrankenMax Full Access Member
    NV
    Amazon or just pm me your address. I’ll send you a couple of them. I have a decent stash.
  5. FrankenMax
    NV
  6. TRCM
    Southeast VA
    Thanks, but i just ordered some.....5 of the standard and 5 of the mini
  7. FrankenMax
    NV
    Glad I could help.
  8. Bacon Sandwich
    Middle Georgia
    For my radar detector I had to get the hard wire kit and splice in a lighter plug because of all the hidden wiring now so I could hide all the wiring. They should have left the fuse box under the dash
  9. IntimidatorRT
    You could have wired it to your mirror
  10. Bacon Sandwich
    Middle Georgia
    Not used to tapping in to other hard items especially when the mirrors now have so many other functions inside them. I miss the simplicity of a fuse box under the dash
