2016 Challenger sxt plus help needed
Discussion in 'Prospective Challenger Owners Forum' started by B5BlueChallenger, Jan 18, 2021.
  1. B5BlueChallenger
    B5BlueChallenger Active Member
    US
    I'm looking at a used B5 blue Challenger and I'm hoping someone can tell me from the photo what this is.
    Passenger side rear looks like it's connected to a sway bar link. It's a braided strap that has broken off of one side. What is this?
    One more thing should I see a faint over spray underneath, is that common from the factory or has it been repainted?
    See attached.
    Raylan Givens likes this.
  2. 2017 Redline HC
    The overspray is factory, I wish they painted the entire underside completely., I dont see the the strap in the picture you supplied.
  3. B5BlueChallenger
    US
    Hi thanks for clearing that up. The strap apparently is a grounding strap on the exhaust. Where does it attach to?
  4. 2017 Redline HC
    I’m not sure I’ve ever noticed that.
    I’ll have a look later to see if my HC has that strap.
    Welcome to the site by the way....
    The exhaust grounding strap helps to minimize corrosion. Also, it suppresses electrical noise that can interfere with the radio, TPMS, etc.
  6. B5BlueChallenger
    US
    Thanks for verifying that for me. I'm surprised the Dodge dealership did not notice this. The car is currently for sale as a certified pre owned. I'm interested but a little leary as well.
  7. Katshot
    Not sure about any of that. As I recall, the ground strap is for the O2 sensors.
  8. B5BlueChallenger
    US
  9. B5BlueChallenger
    US
    Thanks guys sounds like this needs to be addressed quickly??
  10. 2017 Redline HC
    I had a look underneath mine, apparently the HC doesn’t have the same strap. I’d push back to the dealer to make it right.
  11. Cloverdale
    Quite a bit of rust and corrosion. What year's the car and where does it live?
