oil type...
Discussion in 'Dodge Challenger General Discussions' started by LEGENDARY70, Jan 28, 2021.
  1. LEGENDARY70
    TEXAS!
    Hello.
    2010 Challenger srt8 with 98000 miles. what oil do i use? thx
    i have been using mobil1 since I bought my RT. I want to say early SRT owners had to use mobil1 also as it was on the oil cal. not sure in later years
    I am guessing you are asking weight = 0-40
    With 98k on the motor, I would use whatever BRAND was used by the previous owner.
    I bought my 2010 with 8k miles on it in 2018 and use Castrol in all my vehicles
  4. LEGENDARY70
    TEXAS!
    thx
    I have used Mobil 1 0W-40 full synthetic oil in my 2009 SRT since it was new. Great oil and very reasonably priced (especially at Walmart).
    IntimidatorRT likes this.
  6. Katshot
    It’s been years since I had a high-mileage car and back then the answer would be easy. Throw a high-mileage synthetic blend in it. End of story.
    As I recall, your engine is supposed to use 5W-20 oil. If your car has MDS (I think it does), then you need to use the recommended oil or the MDS system will likely malfunction.
    Without MDS, I would probably suggest using a “high-mileage” oil. They may not be the “ultimate” performer that your best full-synthetics are but they are likely better for your high-mileage engine.
    I would be looking for an oil that is both if it’s possible.
  7. 70-426_10-SRT
    NO
    2010 SRT has a 6.1 and uses 0-40w
  8. SRT-Tom
    Also, the 6.1 SRT engine does not have MDS.
  9. Wizard of Iz
    @LEGENDARY70 ... your car certainly left the factory with Mobil1. And as @70-426_10-SRT said, you're way out of warranty so you're free to use whatever you want. The important thing is to use a quality engine oil and filter and change both often.
    I used Mobil1 almost exclusively in all of my vehicles from the early '90s until 2013. That's when we bought a 2013 Charger R/T and my Mopar Master Tech buddy suggested that I should consider switching to Pennzoil Platinum. While the OP's car doesn't have to worry about MDS, our Charger had MDS and I think that Pennzoil provides better protection at idle than Mobil1. (Though I do still use Mobil1 in my Mom's 2005 Chevy Monte Carlo LS (3.4V6))
    One of my favorite YouTube rabbit hole content providers, Project Farm, took a look at popular brand name oils not too long ago. Here's the link:
  10. Katshot
    Sorry, thought he mentioned he had a 5.7
    In that case, I’d definitely explore a “high-mileage” oil.
