Wheel Vibration
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by SRT-Tom, Mar 5, 2012.
    If anyone with a 2010 Challenger has a high speed wheel vibration, have this problem checked out.
    TSB:
    NUMBER: 22-003-10
    GROUP: Tires and wheels
    DATE: August 13, 2010
    THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE TRANSMITTAL 10-050. ALL APPLICABLE VIN's HAVE BEEN LOADED.
    SUBJECT:
    Slight Vibration at Highway Speeds
    OVERVIEW:
    This bulletin involves the removal of all four wheels and the Tinnerman push nuts.
    MODELS:
    2010 (LC) Challenger
    2010 (LX) 300/Charger
    NOTE : This bulletin applies to sales code (WP6 and WPI) built after April 17, 2009 (MDH0417XX) and before May 27, 2010 (MDH0527XX) and sales code (WPT) built after September 24, 2009 (MDH0724XX) and before July 07, 2010 (MDHO707XX).
    SYMPTOM/CONDITION:
    The customer may experience vehicle vibrations which are commonly felt in the steering wheel. A number of vehicles may have been shipped with wheels that do not have the relief cut to accommodate the Tinnerman push nuts used during vehicle assembly. Dealers are required to remove all 4 wheels to remove and discard the Tinnerman push nuts that are used during initial vehicle assembly at the plant.
    DIAGNOSIS:
    If the vehicle operator experiences the symptom/condition, perform the repair procedure.
    REPAIR PROCEDURE:
    1. Raise the vehicle and remove all 4 wheels.
    2. Using side cutters remove and discard the Tinnerman nuts/washers.
    3. Following the procedure outlined on DealerConnect, reinstall the wheels and torque lug nuts to 150 Nm (110 ft lbs).
    Look at the studs at the 12 and 7 o'clock positions in thr following photo:
    __________________
  2. wesalbert
    wesalbert Full Access Member
    Stupid question. How do I know my sales code?
  3. walnetto
    walnetto Full Access Member
    Wisconsin
    Nice find, Tom. Something tells me I have a slight vibration, but it could be in my head. I change my tires when I put the 20" CCs on and off for summer. Will have to remember to look. I should be able to remove those myself.
  4. Storm Rider
    x2 ?
  5. wesalbert
    I think the easiest thing to do is just pull the wheel off and see if it has the Tinnerman push nuts and to see if the aftermarket rims ( I really doubt they do) have the relief cut to accommodate the Tinnerman push nuts.
